It died!! Wondering if ? 03 Golf alh
Devildog
las vegas
03 ALH Golf, 2001 Jetta Tdi
Hi all I was moving along about 80ish and it just died almost like it ran out of fuel but not. When I try to start it now it will start to light and then just turn over. 03 ALH Golf 168k on the clock. I kinda feel like it is fuel related but wondering if anyone else has had this happen and if so what it was.
TIA
Also only code that came up via Vagcom was maf sensor I replaced it to no avail.
Timing belt was done 10 k miles ago.
Has Kermas 165 hp kit , Rebuilt injector pump, Darkside intercooler. southbend clutch , arp head studs.
csstevej
north nj
2001 golf tdi 4 door auto now a manual, mine, 2000 golf 2 door M/T son's,daughters 98 NB non-TDI 2.0, 2003 TDI NB for next daughter, head repaired and on road,glutton for punishment got another tdi 2001NB,another yellow tdi NB , added an 06 NB DSG
Have you checked to see if the TB is intact and tensioned correctly yet?
You think it’s fuel related….is there a huge air bubble in the clear fuel line?
Who did the rebuild on the injector pump?
Mpaw
Europe
Caddy 2005 1,9 105 ps; Polo 2015 90PS Bluemotion, T5 2.5 5cyl
When was the injector pump replaced/rebuilt? maybe check its pressure?
mittzlepick
union maine
2004 jetta wagon (365k)2001 wagon tire burner 6spd 2003 wagon(417k)
relay 109? voltage at the pump shutoff solenoid? out of fuel?
Devildog
las vegas
Yes I have checked the timing belt and it’s good.
Yes I did take a look at the TB and it is good. I was thinking fuel related as it tries To run and then just turns over with no start. The injection pump has only about 10000 miles on it. I believe I bought it from parts place inc. I need to crack the injector lines to see if it’s getting fuel.
Devildog
las vegas
I have not checked the 109 relay as I already replaced it about the same time as the injection pump.
dcjkrueger
Huron, Ohio
Check the CPS ( Crankshaft position sensor ) My 03 Jetta did that quite often before it finally set a code. Cured my stalling and restarting problem.
Prairieview
Too close to Sturgis 'ithole
Two 2000 Beetles, 2002 Jetta, 2002 gas avh Jetta, fleet of older 1.6 turbo and non's
Did you ACTUALLY rotate the engine by hand and see if the timing is actually correct.....cam, crank, flywheel?
Just taking a pointless "look" at the belt is........pointless.
Just seeing the name "parts place" makes the whizz run down my pantleg.
