D-cappz
- Joined
- Jul 10, 2013
- Location
- Victoria
- TDI
- 2003 Jetta ALH, 6 speed, 4motion, fully loaded, leather heated interior, sunroof, steering wheel controls. Over 420,000km
Attention ALH owners that have installed a PD lift pumps or are going to install a PD lift pump. If you have used the ID parts installation guide, you may need to change the ground that comes from relay 53 that they suggested in their instructions. https://www.idparts.com/pd-in-tank-lift-pump-install-kit-p-911.html
I had my PD lift pump installed for almost 2 years prior to any noticeable issues, it did not start to show signs of something wrong till 2 years later.
Every so often my car would stall during idle, never under throttle. I noticed the fuel line had air/foam in them every time this happen. It then would take a while to crank over and finally run again. Now this was not an every day occurrence, but it gradually got worse and worse.
I noticed that the fuel pump would not run all the time, and then noticed that once the car was cranking over or running the fuel pump relay was rapidly turning on and off which in turn the pump was doing the same or just not turning on.
Here is a video of the relay and the instruction from ID parts.
VIDEO: https://www.youtube.com/watch?v=nycgTdz-jXo
This was solved after I posted on a couple Facebook TDI groups. (VW TDI Owners) LINK
Montgomery Schrader sent me a private message asking if I had used the ID parts install guide when installing the PD lift pump (which I had). He informed me that he had the same issue and that the ground that ID Parts instructed to use has a 100ohm resistance which causes a grounding issue. I decided to check if this was the issue by jumping a new ground, and sure enough that fixed the issue of the relay turning on and off rapidly.
I then ran a new ground from the lift pump relay to under the battery where all the other ground run to and i have had 0 issues since.
If you have done this install and fallowed the ID Parts installation guide, i'd suggest checking to see if your relay is chattering on and off. Just to be safe, run the extra 2 foot of wire from the relay box to under the battery trey to the other grounds.
I hope this helps others solve an odd issue.
Thanks so much for those of you that gave some great input/ideas.
Follow my 4motion build @MK4mo_TDI on IG or http://www.facebook.com/MK4moTDI
