I had this on my 2015 Passat when I purchased it from the dealer. They told me VW's official guidance on the known issue is to not replace it under warranty until/unless it causes an actual issue. So I let mine sit and crust over. About a month and a half after purchasing, I started hearing a squeaking noise in the mornings on cold start that progressed to a squeaking noise all the time. Took it in for this noise. I'll make the rest short; this AdBlue leak got down inside the timing belt assembly and ruined the tensioner, rollers, and pump. After 3 trips to the dealer for a continuing squeak caused by the AdBlue leak, they did a complete timing belt job for me, for free.
Lesson to VW: Fix stupid things BEFORE it becomes a problem (I'm not mad about getting a free timing belt job though).
Lesson to OP/anyone else with this issue: Beware of possible damage to timing belt assembly. If you start hearing random chirping/squeaking coming from that area, there's a good chance the adblue got in there and ruined stuff, and if one component is ruined, odds are all of it will go shortly after.
