Tdijarhead
- Joined
- Nov 10, 2013
- Location
- Lawrenceville PA
- TDI
- 2003 TDI Jetta Daughters Car, 2001 TDI Beetle, Wife’s car, 2005 Golf TDI Mine, all 5 spds
Once again it’s time to replace the timing belt on my 05 Golf. I have accumulated 445k miles and I thought as long as I’m doing the belt and the engine has that many miles that it would be a good idea to do some preventative maintenance and “get ahead of the curve” so to speak.
I purchased a Pierburg oil pump kit and all the timing belt bits from idparts and I’m planning on diving in this weekend. It looks like the pump body itself is held on by 3 bolts which seems simple enough. Will I need to remove the front carrier to replace the tensioner and chain?
I have searched for a diy write up on here but can’t seem to find one. Not on the diy list or with a general search. As you can guess I’ve never had to do an oil pump on one of these before, even though I’ve done over a dozen timing belts both BEW and ALH’s.
