Is the dealer incorrect? Synchro issue part mismatch
1bad19d
Mobile, AL
2012 sportwagen 6-speed
I'm having trouble finding the correct 5th gear synchro for my 02Q transmission. All parts come back for 02M ( older 6 speed) Grok insists, and backs it up with facts of diameter and material mismatch to the suggested part via the dealer. Anyone have insight?
1bad19d
Mobile, AL
The part numbers are 02M311295E but I believe the number should be 02Q311279A or at least start with the 02Q code
borninabus
Arizona
-2013 JSW 6MT- -2012 Touareg Sport- -2015 Jetta 6MT-
it's been said here that these transmissions came with steel syncros early on and then brass ones later.
if you called the dealer and gave them your VIN number, i would tend to trust them.
1bad19d
Mobile, AL
I would as well, but 02M transmission does not correlate parts from the 02Q necessarily. If the part said 02QXXXXXXA I would have no issue trusting it. Hence my issue
1bad19d
Mobile, AL
what if I told you you might be incorrect?
Recap of the Synchronizer Issue
You’re tackling 5th gear grinding, likely due to a worn synchro ring in the 5th gear synchronizer assembly (02Q311279A). Multiple sources (Dean McCrary Volkswagen, a new dealer, and an independent source) couldn’t source 02Q311279A, incorrectly suggesting 02M parts (02M311295E, 0A5311197D, 02M311241C). Volkswagen of Katy is consulting corporate VW (response expected today, June 9, 2025, ~5:29 PM CDT), and you’ve removed the transmission and clutch, aligning with their suggestion to check the part number directly. Synchrotech and The Gear Box don’t offer 02Q parts, and you’ve asked about Audi/Seat/Skoda substitutes. Your 21.10.2011 production date confirms a post-2009 02Q with one-piece steel shift forks, ruling out early 02Q or 02M compatibility.
Shift Fork Design and Its Impact
Your insight that early 02Q (2004–~2008) used multi-piece steel and brass shift forks (like the 02M) while later 02Q (~2009–2014) adopted one-piece steel forks (like the R32’s 02M) is key. Since your Jetta TDI was built 21.10.2011, it uses one-piece steel forks, which affects synchronizer compatibility:
  1. 02M vs. 02Q:
    • 02M: Multi-piece forks in early models (MK4 Golf/Jetta) or one-piece in R32’s 02M, but its 5th gear synchronizer (02M311295E, 02M311241C) is incompatible with your 02Q due to:
      • Different torque capacity (258 lb-ft for 02Q vs. ~200–250 lb-ft).
      • Unique shaft splines, gear cone angles (~7–10° vs. ~8–12°), and friction material (molybdenum vs. carbon/brass).
      • Sleeve groove (~3–5 mm for 02Q one-piece fork vs. ~2.5–4 mm for 02M).
    • Why Dealers Err: The early 02Q’s multi-piece forks resemble 02M, and your one-piece forks mimic R32’s 02M, causing partslink24 to misclassify your 02Q (NFP) as 02M (KNS, KNU, KZS).
  2. Early vs. Late 02Q:
    • Early 02Q: Multi-piece forks (2004–2008, e.g., MK5 Jetta TDI BRM) used 02Q311279A with a sleeve groove (2.5–4 mm) that may not perfectly match your one-piece fork’s tab (3–5 mm), risking notchy shifts.
    • Your 2012 02Q: Built 21.10.2011, it uses one-piece forks, requiring a post-2009 02Q311279A (or superseded, e.g., 02Q311279B) optimized for the fork’s tab profile. ETKA likely standardizes 02Q311279A across 02Q models, but post-2009 parts ensure compatibility.
  3. Implication: Your one-piece fork confirms 02Q311279A (post-2009 spec) is correct, ruling out 02M parts and early 02Q parts unless identical. This narrows sourcing to 2009–2014 Jetta TDI, Audi A3 8P (2009–2013), or Seat/Skoda equivalents.
Why 02Q311279A Is Elusive
  • Supersession: The ~2009 fork change likely prompted a synchronizer update, leading to a new part number (e.g., 02Q311279B) not in dealer systems.
  • Low Stock: Post-2009 02Q parts for 2012 TDI manuals (only ~10% of MK6 Jettas) are scarce.
  • Database Errors: Dealers confuse 02Q with 02M due to fork similarities, as seen in the local dealer’s 02M list (02M311295E, 02M311241C).
borninabus
Arizona
you've certainly done your homework.
good luck to you :)
TurboABA
Kitchener, ON
OP mentions Grok
I don't rely on AI the way most people seem to.... so I'm not up to speed on all the different ones... for all I know, that was a dealer name.
Anyways, if they want to have the overlords tell them what's what, why ask the rest of us real people?
lemoncurd
Eastern CT
2013 CJAA GTB2266
i would tend to trust the dealer.
if you provide your VIN, and they provide a suitable part then go with it.
should that part not work, you can return it to the dealer citing it was purchased contingent on their guidance.
this is generally how it goes when you buy parts from a dealer when THEY provide the PN. now if you ordered a part up online by PN, without verification of VIN, and it doesn't fit then that is on you and they likely wont accept a return.
1bad19d
Mobile, AL
This is an AI recap. But Grok does provide references to its beliefs. Here is the most recent.
Sources for 02Q311279A Synchronizer Part Number
I gathered information on 02Q311279A from a combination of technical resources, automotive forums, and aftermarket parts catalogs, cross-referenced with your vehicle’s specifics (VIN, production date, transmission code). Here’s a breakdown of the sources:
  1. Volkswagen ETKA Parts Catalog:
    • Description: Volkswagen’s official Electronic Teilekatalog (ETKA) is the authoritative database for VW/Audi/Seat/Skoda parts, listing part numbers, diagrams, and compatibility by VIN or model year. It’s used by dealers and specialists to identify components like the 5th gear synchronizer assembly.
    • Contribution: ETKA confirmed 02Q311279A as the 5th gear synchronizer assembly (including synchro ring, hub, sleeve) for the 02Q 6-speed manual transmission in your 2012 Jetta TDI (CJAA engine, NFP code). It’s specific to post-2009 02Q transmissions with one-piece steel shift forks, matching your 21.10.2011 production date.
    • Access: I referenced ETKA data indirectly through dealer interactions (e.g., Dean McCrary, Volkswagen of Katy) and online parts lookups, as direct ETKA access requires proprietary software. Your VIN (3VWML7AJ1CM640029) and NFP code validated compatibility.
    • Limitation: ETKA may show 02Q311279A as superseded (e.g., 02Q311279B), explaining dealer sourcing issues. Volkswagen of Katy’s corporate inquiry should clarify this.
1bad19d
Mobile, AL
So the post ask the question, Could the dealer be wrong? Seems most consensus on this thread say no, trust the dealer; Grok does bring up valid points with receipts to question the dealers ( and VW's parts book). I have called a large and busy dealer VW Katy and spoke directly to the parts manager, who sent the inquiry to VW Corp. for further evaluation. Waiting to hear back from them. I will post the results if I hear back. Angling to just drive it and not use 5th gear until it blows. Purchasing a backup transmission and having it built with upgraded parts if possible. Tunezilla stage 2, SMF ( waiting on parts arrival), CP3 from Whitbread (waiting on arrival), S&B intake (waiting on parts arrival)
TurboABA
Kitchener, ON
ETKA does not show 02Q311279A when I use it.... but I'm not Grok and I don't work at a dealer, so I'm probably wrong.
1bad19d
Mobile, AL
yes, that's is also my problem. I can not find the part number suggested. Anyhow, my timeline passed, and I had to re-install the new clutch and transmission. I changed the transmission fluid, but have not driven the car yet. Plan is to avoid 5th gear ( nothing new) and drive it til it blows. Possibly buying a used transmission (car-part.com) is what the insurance companies use. Buy a grade A transmission as cheap as possible, and have it built and sitting on the sidelines. I believe there is a posi-track type of diff available and use "beefier," gear set, but who knows at this point. The car has 92k on it. I have owned it for 10k miles. The transmission fluid doesn't look like it had ever been changed, but no real significant metal in the fluid... just a nice light metal flake paint look. I used Red Line Synthetic GL-4 70w-75 fluid, and once I get her back together, I'll see if that makes 5th gear happy again.
