TurboDieselPoint
Now that it has been below freezing for a couple of days, I have finally been using the heater and I noticed something I hadn't previously observed. Once the car is up to operating temperature (above 200*f), I can cool off the coolant temperature when I turn the heat to MAX with recirculation off and crank the fan speed to six with the engine idling. This evening it was 28*f outside, and with the engine idling and the heat on full as I described, the coolant temp went as far south as 180*f according to my Scangauge II in just a couple of minutes before I shut the engine off.
Seems to me the thermostat should prevent this from happening, but I'm not sure. Is this normal? Those of you with Scangauges, can you tell me if your car behaves this way also?
Thanks!
TurboDieselPoint
Thanks!
TurboDieselPoint
