is it normal for 2015 TDI SEL Take 6 minutes to turn off ?
kabir93117
santa barbara ca
2015 tdi
The car had been a commuter car it has 150000 ..now i drive 11 miles in the morning and 11 miles home ..it sits all day .today at .5 pm took 2 minutes to turn on . then i sit for one minute to warm up. .drive 11 miles home .oil temp 199 .back in to my driveway .took 6 minutes holding the button foot on the brake to turn off .oil drops to 197 then turned off .is that normal? .i have only had this car a month .most time its faster turning off .like 2 or 3 minutes some time turns off when i hit the button ..some times it take 2 or 3 minutes to turn on or off today it took the longest .thank in advance ..
NSTDI
Nova Scotia
15 Passat
Mine has always turned off instantly when I hit the button, turns on instantly too, unless cold weather and I have to wait a few seconds for glow plugs.
eugene89us
Southern USA
2014 Volkswagen Passat TDI SEL Premium
I have to push the button right in the middle and hard enough to make adequate contact to start or stop. In the heat of the summer, the engine stops right away but fans may be delayed by 2 to 3 seconds (not in regen). Some delayed shutting down of fans I noted lately, but not the same as after regen is interrupted when fans can run for a few minutes after. When you speak of time to turn off, does your engine continues to run at idle RPM or are you hearing the fan noises only with engine RPM at zero? I am sorry for a rudimentary question, but I have never experienced car not starting or stopping, except if I don't push the start button properly and it makes no contact, then it is like pushing a placebo button. You push it again and all starts and stops immediately.
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
ooo did not know that . i having the button replaced
If you have a dirty button, you could turn the car off and if you hit the button again while it's off with the foot on the brake. The engine will start.
I went cheap and took my button apart, it had soda spilt on it and onced I cleaned it. It acts brand new now.
kabir93117
santa barbara ca
2015 tdi
i am not the best at putting the trim back .. what year is yours ? mine is 2015. how do you take the shifter trim off ..did it snap back in easy ?
x1800MODMY360x
AZ, USA
2013 Passat TDI SEL
I left the shifter boot on the trim piece, it's a little tight but just need to remove the electrical connector and push 2 tabs to pop the start button out.
2012-2015 have the same body for the most part.
Here is a video, the trim will be the same, but I think the button is different on the 2015 for disassembly. I would pull from the top by the door compartment lip than what he did.
Outlier
Savannah, GA
2014 Passat TDI SEL - organ donor (R.I.P)
You don't think about how often you actually use it but it does get a fair amount of wear/usage. I don't know what they go for now but it was worth the $130 and 20 minutes it took to replace it. Mine wanted to try and start and turn off like an immobilizer issue.
740GLE
NH
amazing how these mobile techs are blowing up repair jobs.
DivineChaos
Minnesota
mk6 jetta sportwagen tdi
I've been having clean mine every year. I've been debating on finding the wires and adding a dual pole momentary switch in the center. Because that's all they are isn't it? A momentary button?
