Is anyone familiar with fault code 01336
rarmstrong
Charlotte
2004 Passat TDI
I am hoping someone could steer me in the right direction. I went to have the glow plug recall done (back to ceramic from steel) and they couldn't complete due to an "intermittent" fault to convenience bus. The info is below. Is there a way I can fix this? or am I just srewed. :(
Thank you for the help!
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 A
Component: Lenkradelektronik 0005
Coding: 00118
Shop #: WSC 05311
VCID: 2F6715D3C786
1 Fault Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 C
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
Shop #: WSC 09250
VCID: 2757FDF3EF76
WVWPE63B44E316087 VWZ7Z0D9557705
1 Fault Found:
80-10 - Single-Wire Operation - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
VCID: F0E556AF9A38
1 Fault Found:
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 05311
VCID: 37772DB33FD6
Part No: 1C1959801
Component: 08 Tõrsteuer.FS KLO 0202
Part No: 1C1959802
Component: 08 Tõrsteuer.BF KLO 0202
Part No: 1C0959811
Component: 08 Tõrsteuer.HL KLO 0202
Part No: 1C0959812
Component: 08 Tõrsteuer.HR KLO 0202
1 Fault Found:
DeliveryValve
Western US
Passat GLS Wagon
From the Ross-Tech website.
http://wiki.ross-tech.com/wiki/index.php/01336
01336 - Data Bus for Comfort System: Faulty
Possible Causes
CAN-Data Bus faulty
Wiring/Connectors from/to Control Modules
Control Module in CAN Data Bus Comfort faulty
Possible Solutions
Check CAN-Gateway Coding
Check Measuring Value Blocks (MVB)
Check Wiring/Connectors from/to Control Modules
01336 - Data Bus for Comfort System: Single-Wire Operation
Possible Symptoms
Data Bus Comfort working in Single-Wire Mode
Possible Causes
Possible Solutions
Special Notes
When found in VW Passat (3B): Comfort System, check Comfort Control Module and Door Control Modules.
Wiring/Connectors from/to Door Control Modules faulty
Comfort Control Modules flooded/faulty
Doing another search on the code. There is a hit on door lock issues like the Ross-Tech explanation provides. Are your door locks working? You might also want to check the wire connection to the Control Module is not corroded.
Hopefully someone else will chime in to add more info about this code.
rarmstrong
Charlotte
2004 Passat TDI
Thanks Richard, I just thought of this too. Occasionally, my car will lock itself! Eveen if my key is in the ignition...can't remember exactly if I had the car on, or turned to accessory...but it locked (has done so a couple of times)...luckily it was summer and window was down. *(I don't have a spare key so this does scare me). Do you think that this may be causing the fault? Thanks for your help! Thanks to David Hood for graciously running the codes and setting timing for me yesterday.
DeliveryValve
Western US
Passat GLS Wagon
Yes it sure looks that it can. Based on the info you provided, I would start looking into the wires from the door jamb into the control modules. Which means removing the door panels and start inspecting the electrical lines. It could be cracked wires or corrosion in the connections.
mk3
Wisconsin, USA
03 Jetta GLS 5-speed
Regarding the door open/closed switches, I have had three of them fail and replaced 4 overall, including having made one bad repair I have done the job 5 times.
I have never seen a CAN bus error nor heard of an error like this coming from the door switch. I think a good approach would be to inspect the wiring - but unfortunately that is extremely labor-intensive.
Checking the CAN communication wiring is the correct thing as others have pointed out - I just wonder if there would be some way to narrow the investigation such as by unplugging different modules temporarily and then checking the CAN bus health, assuming there is a way to do that.
DanG144
Chapin, South Carolina, USA
2005 A4 Jetta 5spd
I have seen broken door wiring in the early A5 platform cause CAN bus errors and battery drain from computers not going to sleep.
I have not seen this on the A4 platforms from bad door switches.
When door or hatch wiring is suspect, start with the accordian pleat grommet from the body to the moving panel. Just pull it out of one side and then the other, collapsing it as far as possible. So far this has worked for me.
I need to learn more about the CAN bus errors, so I will be reading with interest.
rarmstrong
Charlotte
2004 Passat TDI
This member is having a similar locking on it's own issue, the thread maybe of some help.
http://forums.tdiclub.com/showthread.php?t=334883
I will check out this thread. Hopefully he can run a scan and tell me if he is getting the same fault code. It would be great if I could just change the relay in the door. My problem is very intermittent though. My interior lights work fine as well.
vwztips
Greenville, SC
2005 Passat GLS Wagon TDI 5 spd manual w/BSM delete 2011 Tiguan TDI/DSG 2005 Audi A4 Avant 6MQ TDI 2011 BMW X5 35d
First check to see if your ccm is wet or corroded internally.
