lbitto
Howdy,
Some background. I left my car in a lot for 2 weeks. I think it was losing prime, but I after resealing the injection pump I found out I had a bad 109 relay. Replaced that.
The injection pump is leaktight as I tested it with a mityvac. I may need to remove the check valve at the sender unit, and am waiting on a part to seal the thermostatic tee on the filter... in the mean time i decided to isolate just the injection pump and tried the bottle method and just feed the IP diesel that way.
The ongoing issue i have is that I can't seem to get the hard lines to bleed. Or, at least I get two lines to squirt fuel but it's almost like there's not enough pressure to get them to bleed. Also, some fuel would be pulled from the bottle, then quickly back with alot of air bubbles, almost like the pump couldn't pull the fuel. I tried adjusting injection quantity by hammering the head to the right; it stopped pulling and pushing the diesel from the bottle and the flow seemed to be steady. No change in trying to bleed the hard lines. Two seem to bleed, not necessarily the same two each time. That's with all the injector fittings cracked, or one by one.
I double checked the timing belt. Cam, crank and fuel pump pulleys are where they should be. I was extra careful to assemble the IP so that it wasn't 180 off, so im 98% sure that's not the issue. The case pressure relief valve is intact and everything is pushed in flush. I did lose one of the rubber grommets for the valve cover and am waiting for a new one. I highly doubt that affects anything related to fueling, but figured id include.
I've been racking my brain trying to go through every possible issue. I really don't want to buy a new injection pump
Thoughts?
UPDATE:
I was able to resolve this issue. I chalked it up to a sticking fuel shut-off solenoid. Jumping a wire straight from the battery to the solenoid seemed to help it open so that I could start it. I replaced the normal wire and tried starting, and it fired right up. It also could have been some loose grounds, which I resecured.
Hope this helps the next person who has this issue.
Thoughts?
UPDATE:
