IP top and bottom seal how-to (?)
52172
Buellton, Ca
2001 Golf TDI GLS
We’re gonna first clean with brake cleaner and do two top seals and test run for leaks then only do the head seal if I still have leaks. All this can be done with pump left on car it seems?
52172
Buellton, Ca
2001 Golf TDI GLS
Corrado what shop is yours do you sell the seals and tool online? Should we replace the temp sensor while in there? Thanks
corrado tdi
TDIClub Enthusiast, Vendor , w/Business number
San Antonio, Texas, U.S.A.
2016 Golf TDI
I run Dieselgeek.com and you can order seals there. I only recommend replacing the fuel temp sensor if you are having timing stability issues.
KLXD
Lompoc, CA
'98, '2 Jettas
If you understand that the VE pump is one of the highest precision assemblies in the automotive industry and take precautions to avoid getting dirt into the pump while changing seals, especially the head seal.
52172
Buellton, Ca
2001 Golf TDI GLS
I’m having diesel injection service reseal it. I also found a rebuilt 11mm pump in Poland that is only 350 dollars with a 12 month warranty if the reseal doesn’t work.
Texas
2013 Sportwagen, 2012 Golf
Just curios how close the fuel quantity comes using this method. When I used a vag com to dial my daughters in, imperceptible movement changed the reading quite a bit.
corrado tdi
2016 Golf TDI
I've been selling pump seals for 15ish years and I can say the JB-Weld method is the best at getting the QA back to exactly where it was prior to changing the TDI injection pump seals. Having four fracture zones to match up is very accurate.
pahHONEix
Nashville
'03 Jetta GLS TDI
Hey all, just wanted to chime in with my experience replacing both quantity adjuster seals on my '03 Jetta TDI today. Everything went pretty well, I used score marks and Sharpie pen marks to align the bottom edge of the QA to where it was originally mated to the injection pump. After I got both new QA seals installed (from the deluxe Dieselgeek seal kit) I put everything back together, reprimed the fuel system and started the car.
Initially the idle was pretty rough: at first it would sit at around 1,150 to 1,200 rpm, lope like crazy, and smoke. The readings I was getting through VCDS said the IQ was bouncing (even when the car reached operating temp) from 0.0 to maaaybe 1.0 or so. When the engine warmed up the idle smoothed out a little but it was still about 2-300 rpms high. I noticed the gas pedal still worked and the engine accelerated normally, but at idle it sounded awful.
The next day I dug into it all a little more, used the Hammer Mod to get the idle rpm down to its usual 903, and I started seeing more stable IQ readings on VCDS. After that it was just a matter of dialing in the IQ via VCDS to get it where I wanted it. Right now I've got the IQ set to 4.0 exactly at a coolant temp of 91.7 degrees and the idle rpm still at 903. I've only put about 10 miles on the car since I got all this done but so far it seems peppier and drives fine. And I haven't noticed any leaks around my QA or injection pump which was the whole idea so...great!
If I had to do it all over again I maybe would have used a paint pen or something for my marks on the QA/IP but that was about it. This was the first time I'd seen my car really run/sound awful so that was kinda jarring at first, but it was nothing patience and hitting it (lightly) with a hammer couldn't fix. Thanks again to this 11 year-old thread and all the expertise/ideas it contains! Hopefully it continues to help people out down the road.
DC-TDIWagon
DC (really Fairfax county, but it is easier to say
2003 Jetta TDI Wagon, Reflex Silver
I appreciate how fast you ship and how well you document things on your website. I smelled diesel after driving my car and popped the hood on Monday to find a weeping leak on my quantity adjuster. Ordered from you kind of late on Monday and my package should be here in a couple hours. I used your viton head seal kit last year and that went great. Probably should have just bought the deluxe, full kit back then to have the two quantity adjuster seals laying around.
JimInPB
Florida
1999.5 ALH Jetta
I had my first serious injection pump leaks, probably about 2 or 3 years. ago. I bought a seal kit & special tool for the special bolt head. I only changed the top seal at that time and did not need to mess with injector adjustments. A month or two ago, I had serious leaks from the lower seal. I got a copy of VCDS and took baseline readings before doing anything else. I then cleaned around the injector pump real well, scribed the sides of the pump in a few places & opened her up. I worked clean. The seal swap was easy. When I put it back together, I lined up the marks as well as I could. The motor idled poorly when I started her back up. IQ was below 1. The hammer trick fixed it. If I was going to do this again, I would put the pump back together with the lid slightly towards the passenger side, to run a little rich, rather than lean on first start up before tuning, just to make life a little easier.
While I was in there with VCDS, I looked around a little & found that my injection timing reads as being a little slow. The car has been running well for the several years that I have owned it, so I am a little less then enthusiastic about opening that can of worms unless there is a good reason to do so. I am left to wonder if slightly slow timing might cause crud to build up inside the motor some where. If not, I may just let that sleeping dog lie.
AndyBees
Southeast Kentucky
Changing out the top and bottom seals will not affect timing. Loosening the three bolts on the IP Cog will affect timing. But, considering you have VCDS, setting or re-setting the timing should be an easy straight forward procedure! Was the Timing below the graph center line?
burn_your_money
North Bay, ON
99 Beetle, 96 B4V, 05 Passat wagon
As long as your timing was between the upper or lower line, it's fine. Some guys like to run it above, some like to run it below. I forget how it's perceived , one is more power, one is more fuel economy. The computer controls the timing anyways under most situations anyways.
Crusty
Idaho
98 Jetta
I would also like to say thanks to corrado tdi. Got my parts fast, and it was easy to do
Pedalsteel
United States
Unicorn
I'm going to chime in with my experience doing this and add something in case someone else can use the info...I tried the blobs of jb weld which sat overnight and they shot off the pump when I went to tap with the dowel...I had anticipated that though and used a combo of spring loaded center punch right on the seam between the middle part of the top of the pump that moves and the bottom part... this puts a half punch mark on both sides and I used my phone to take a picture before I took it apart and I also took a dremel tool and put a diagonal line in two spots one on the driver's side of the pump facing the left front fender and another one facing towards the windsheild...I took pictures of those also and then once I got everything back together I eyeballed the two as close as I could get them and then took two pictures and with the zoom on the camera I was able to compare the unopened pump pics with the resealed pics to know how to tap the center to get it exactly in place... when I first started the car it was rough running at like 1100 rpm and then once I compared the pics and tapped the middle part to match the original unopened pump pics, it runs right at 903rpm and feels great...I still have to hook it up to find out the exact number for the iq and maybe do the hammer mod but it's real close to where it was...the center punch marks and dremel marks are the way to go in my opinion
