I am dealing with a frustrating issue for a couple of years now. I had an IP which was leaking fuel from the seal , replaced it a few times(the seal) ,tried it with a sleeve once but it would always go back to leaking after about 10k miles
Replaced it for a used IP which didn't seem to have any leaks from the shaft but I put in a new quality seal any way and also exchanged for a new sprocket just in case the old one was unbalanced and caused wobbling which would brake the seal , but again after about 10k it started leaking again
Could it be that both shafts are worn and never been replaced ? Really dont know what else to look for and its time consuming for me to keep opening the timing all the time.
Is this a known issue with these pumps?
Any input would be greatly appreciated
Thank you
Thank you
