Internal Control Module Memory Error (vag com)
Vinyl_Addict
Allentown PA
00 Jetta
Sorry if this was addressed, but i searched and couldn't find it.
i am getting this code
65535 -Internal Control Module Memory Error
35-10 Intermittent.
i'll clear it and it comes back a few minutes later.
rdkern
Humboldt Co CA
tditom said:
I'll bet its the tubing inside the ECU box. Check/replace all the tubing connecting to the N75 valve.
see this thread
Good chance that this is the problem.
Otherwise - look at the hose that connects the ecu to the innercooler. It tends to rub a hole it in, and may have the same error code as the little one inside the ecu.
alphaseinor
TDI Innovator Vendor , w/Business number
Denton, TX
'03 Jetta TDI 780,000 miles (totaled out), 01 Audi TT 225 Quattro 230,000 Miles (runs great!), 00 Cabreetle Beetle dash, ALH & MK4 harness Swap
vacuum line time!
Vinyl_Addict
Allentown PA
00 Jetta
alright i'll check that line
i already replaced all my vacuum lines a little over a year ago, maybe it came loose.
Birdman
Near Hagerstown MD.
Jetta 2001 Died by Truck one snowy day. Jetta 2003
Did you open hate ECU and change the tube inside the ECU?
Vinyl_Addict
Allentown PA
00 Jetta
i just changed the tube inside the ecu.
how important is it to have the ecu supported by the 3 bolts? I broke the rear plastic "pin" trying to get it back in. Anyone know the part # for that if its essential?
alexpodea
Seattle, Wa
96 Passat
did you find what the problem was? i have the same issue and don't know what to do, what to replace or fix. any ideea?
rdkern
Humboldt Co CA
alex - did you read the advise given to vinyl_addict? Follow the suggestions in the thread, and see if it works for you.
