Hey all. I'm by no means any kind of expert with electrical/wiring issues in my car, and thankfully my 03 golf hasn't had any real electrical issues...until recently.
Started about a month ago; heard what I thought was a turn signal clicking, going on its own. I was about to head off on a 3 week road trip, where I would be off in the mountains/desert and was getting somewhat nervous about random electrical bugs getting worse during my travels, but despite all the clicking and associated locking issues, I made it back in one piece. My original battery in the car (not bad, OEM battery, not bad!) died on the road trip, so I replaced it with a Wal-mart replacement. This new battery has been good so far!
Now, in trying to troubleshoot what the clicking issue is, I am kinda stumped.
The sound that it makes from the dash somewhere is a steady clicking sound, not the typical turn signal/4-way flashers sound - it's faster than that and seems to have nothing to do with the turn signals or 4-ways. I tried this fix just in case it could've been related: http://forums.tdiclub.com/showthread.php?t=167831 but it didn't do anything.
The problem started on its own, and it clicks most of the day now. Key in the ignition or not. Locked or unlocked. Seems like it's somehow tied into the lock system, as my locks usually don't work while it's doing its clicking. Haven't been able to open the rear hatch in weeks via both the button on the fob or the hatch release on the driver's door. To get any door other than the driver's door to unlock, I've usually got to hit the unlock button on the key fob a whole bunch of times as well.
[side note, the lock cylinder in the hatch doesn't match my key, as I had to swap it out years ago, after it got so corroded from road salt that crud was getting in, and actually preventing me from physically opening the hatch at all; so I put in another random cylinder that actuated properly...just electrically though, not manually with the key. Anyway, this cylinder swap had only ever limited me in that I couldn't use a physical key any more to open the back; no big deal...till now]
Lately, when I get in my car, and start the ignition, it's still clicking before I fire up, and continues after starting. Once running, it'll usually stop clicking if I hit the unlock button on the driver's door, and it also usually starts clicking again when I step out of first gear into second. It may or may not stop clicking during my drive; how ever long the drive is.
Also, the windows are affected too. When it's doing its clicking thing, the window controls are intermittent (I might need to press the up/down button for the windows to get them to move, maybe 20 times total to fully open or fully close them, after jerky movements up or down).
A knowledgeable VW buddy of mine suggested I look at the grounds under the battery tray. So I took the new battery out today, looked under the battery tray and found a fair bit of corrosion on one of the grounds, and some pooling water nearby to that ground point. Went to loosen it so that I could start cleaning it up, and the bolt (or stud?) sheared right off pretty easily, so that's a new issue (I think it's ground #65, according to http://web.mit.edu/dennis/www/vw/grounds.html as the ABS light stays on now, along with a flashing e-brake light). I'll probably use one of the 4 battery tray bolts along with a washer and some dielectric grease to use as a new ground for the one I sheared off, unless you guys have any better ideas? It was starting to snow into my carport, and I was losing daylight, so I buttoned everything back up, without those 2 ground wires taken care off...that's tomorrow's project.
Manually checked the relays for corrosion under the dash, above the foot pedal area, as well as the fuses. Before taking my steering wheel apart to check the clock spring/stalk for gunk, I also checked out the 4-way switch, and it appears fine, but still clicks with or without it plugged in. Not sure if that's related...
That's where I'm at so far. I ran my vag-com before I looked under the battery tray and sheared off that bolt, and pre-bolt-destroying, the output from VCDS was as follows:
Saturday,05,December,2015,14:48:53:49638
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
www.Ross-Tech.com
VIN: 9BWGP61J834067372 License Plate:
Mileage: 260800km-162053mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWGP61J834067372 Mileage: 260800km-162053miles
Address 01: Engine Labels: 038-906-012-AGR.lbl
Part No: 038 906 012 GN
Component: 1,9l R4 EDC G000SG 4308
Coding: 00002
Shop #: WSC 00000
VCID: 62C1A64CEE8E572E1D-49C0
9BWGP61J834067372 VWZ7Z0C7060387
4 Faults Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 35-10 - Electrical Fault - Intermittent
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 35-10 - Electrical Fault - Intermittent
16785 - EGR System
P0401 - 35-10 - Insufficient Flow - Intermittent
16512 - Coolant Thermostat Valve (N214)
P0128 - 35-10 - Temperature below Control Range - Intermittent
Readiness: 1 4 0 0 0
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0019458
Shop #: WSC 00000 785 00200
VCID: 346D101454FA899EBF-4FE2
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0003
Coding: 12344
Shop #: WSC 00000
VCID: 2757F758C52CF2060A-4FC6
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 806 L
Component: KOMBI+WEGFAHRSP VDO V07
Coding: 07332
Shop #: WSC 00000
VCID: 30651C04F0E2B5BEDB-4FAA
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
01304 - Radio
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00000
VCID: 70E5DC043062F5BE9B-4FAA
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00000
VCID: 37772718158C62869A-49C0
Subsystem 1 - Part No: 1C1959801A
Component: 8C Tõrsteuer.FS KLO 0009
Subsystem 2 - Part No: 1C1959802A
Component: 8C Tõrsteuer.BF KLO 0009
Subsystem 3 - Part No: 1C0959811A
Component: 8C Tõrsteuer.HL KLO 0009
Subsystem 4 - Part No: 1C0959812A
Component: 8C Tõrsteuer.HR KLO 0009
5 Faults Found:
01389 - Tailgate Open Switch (F124)
27-10 - Implausible Signal - Intermittent
01038 - Central Locking Thermal Protection
35-00 - -
01334 - Door Control Module; Rear Right (J389)
49-10 - No Communications - Intermittent
01333 - Door Control Module; Rear Left (J388)
01299 - Diagnostic Interface for Data Bus (J533)
End-------------------------(Elapsed Time: 05:48)--------------------------
Regarding the EGR code, I did an EGR delete years ago and currently have a Dieselgeek race pipe installed. The glow plug code is probably the harness, and has been an ongoing issue for a while that I just haven't gotten around to addressing. Coolant thermostat has also been acting up for the past few months, but also haven't given it a high priority to replace it yet. Radio is not stock, so I get that error regularly too. Everything below that are all brand new codes though (all the central convenience stuff), and started only after the clicking issue came about.
Only other issues, which are probably unrelated, are that the passenger's heated seat no longer heats, and there's a mild exhaust leak somewhere that leaks into the cabin when I'm stopped at a light, idling, after long drives (again my troubleshooting hasn't gotten me very far with this one).
Any friendly guidance? This is really the only electrical issue I've ever had with this car, and I'm open to suggestions/criticisms!!!
www.Ross-Tech.com
76
Coding: 00002
Shop #: WSC 00000
4 Faults Found:
16785 - EGR System
Coding: 0019458
Coding: 12344
Shop #: WSC 00000
Coding: 07332
Shop #: WSC 00000
2 Faults Found:
01304 - Radio
Coding: 00006
Shop #: WSC 00000
1 Fault Found:
01304 - Radio
Coding: 00258
Shop #: WSC 00000
5 Faults Found:
35-00 - -
