Intermittent Low Power
wrenchtech
Lake Geneva, Wisconsin USA
2005 Golf TDI
The engine in my 2005 Golf has a problem featuring intermittent low power. When climbing a hill, or trying to hold highway speed, the vehicle sometimes runs roughly and surges when pushed beyond approximately 3000 rpm. Just shutting the engine off for a few minutes is often enough to restore normal function. The car is showing a check engine light which I have not yet checked, because I was used to it being on intermittently due to a glow plug issue.
Rx7145
Ohio
2006 Jetta BRM
Well, you need to see what that code is. sounds like it’s going into limp mode probably due to over or under boost.
