eb2143
Resolved: It was a boost leak! Intake manifold...bolts fell out. I seem to have fixed my VC and vacuum pump seal leak with gray gasket sealer.
I have an interesting one for you all. Car is in signature. I know I need to get under the car to attempt to diagnose, but time is scarce at the moment and I wanted to see if this could be a DMF failing.
For about two weeks it has been intermittently loud at idle. Otherwise running like a top. The sound is difficult to describe, but it's not a tick, rattle, screech, or metallic exhaust rubbing sound. It's similar in pitch to normal diesel clatter, but it's LOUD for a TDI, it sounds like a Cummins 12 valve from inside. There is no vibration in the cabin. The rpms are holding steady -- it's not a rough idle in that sense. The engine sounds great going down the road and accelerates smoothly. It makes no difference whether the clutch is in or out. But, it goes away as soon as I increase the rpms. Again, it's ONLY at idle and if I raise the rpms to 1000 the engine actually gets quieter and sounds exactly like it always has at 1000 rpms.
The loud idle comes and goes. It's never been present when I first start the car up (so far only noticed on warm engine, but not reliably so). Last night a normal idle actually devolved over the course of 5 seconds into this "jackhammer" idle as I was sitting at a stop light.
The strangest thing is that when this loud idle is occurring, if I step outside the car and pop the hood, the engine sounds totally normal!
I'm learning toward a motor mount issue especially because of the last point that the engine sounds normal when you have your ear to it. Maybe there is some sort of resonance being transmitted to the car's body thru a mount?
I'm suspicious because everything MEYLE I've ever installed on this car has failed prematurely, and I have a MEYLE dogbone with 50+k installed. On the other hand, the clutch is original and the takeup is rough (lots of feathering needed with the throttle). I know it's getting close to time for a clutch and flywheel -- could this be the first signs of DMF disintegration? Could be some injector issue?
TIA.
TIA.
