jonlowe
2005 Passat TDI
I'm getting the above fault intermittently. I removed the V157 intake manifold flap assembly and cleaned a bunch of soot off of it this weekend, but I'm still getting the fault. I cleared the fault, it stayed away for a few days, then set a DTC again. Is there a way with VCDS to cycle the flap assembly with the ignition on, but the car not running, so I can see if it is sticking or there is a dead spot in the motor that drives it? I know there is a way to cycle the EGR valve, but I haven't seen anything on the flap.
Thanks,
Jon
Thanks,
Jon
