GassinGerhard
- Joined
- Nov 11, 1999
- Location
- Santa Cruz Mountains, CA
So the glow plug light started flashing then it went out. Then I found out my brake lights weren't working all of the time. So I pull the switch out and it works fine when I check for continuity. So I stick it back in and the brake lights work fine. Then the stupid glow plug light starts flashing again and the brake lights aren't working. So I remove the switch again, put a jumper across the contacts of the electrical connector and everything works fine. One more check at the VOM meter and everything checks out OK. I re-install the switch and my brake lights work again. I wouldn't be surprised to find out that the stupid glow plug light comes back on again tomorrow morning on the way to work and my brake lights quit working. It's a four pin switch BTW, part number 1J0 945 511A. Any ideas?
