Interior Trim part numbers FYI...
Kennedy
Fredericksburg, VA
Sent these to Chad so he could put together kits to sell since he has access to German parts... This was a PITA to compile.
Unless you already has a trim kit installed they'll need a new radio cage, see previous post..
Cupholder cover:
1J0 858 585
D 93A - Myrtle
D 2WE - Burr Walnut
E 2ZS - Black Brown Net Optic
E 2B9 - Black Anthracite Net Optic
E 4J4 - Brushed Aluminum
E 2J7 - Satin Black Aluminum
E 7AZ - Silver Gray
Left Strip:
1J0 853 189
93A - Myrtle
2WE - Burr Walnut
A 2ZS - Black Brown Net Optic
A 2B9 - Black Anthracite Net Optic
A 4J4 - Brushed Aluminum
A 2J7 - Satin Black Aluminum
A 7AZ - Silver Gray
A 2S2 - Black Silver Net Optic
Right Strip:
1J0 853 190
93A - Myrtle
2WE - Burr Walnut
A 7AZ - Silver Gray
Lower Trim:
1J0 858 035
A 93A - Myrtle
A 2WE - Burr Walnut
B 2ZS - Black Brown Net Optic
B 2B9 - Black Anthracite Net Optic
B 4J4 - Brushed Aluminum
B 2J7 - Satin Black Aluminum
B 7AZ - Silver Gray
B 2S2 - Black Silver Net Optic
Drivers Door (4 Door):
3B1 867 171 C
FEM - Satin Black Aluminum
FEN - Flannel Grey Aluminum
FEP - Light Beige Aluminum
MJQ - Satin Black Silver
NPX - Satin Black Aluminum Brushed
PES - Flannel Grey Aluminum Brushed
F FEQ - Nut Brown Wood Satin Black
F FER - Nut Brown Wood Light Beige
F FRK - Nut Brown Wood Flannel Grey
F LML - Myrtle Wood Satin Black
F LMM - Myrtle Wood Flannel Grey
F LMN - Myrtle Wood Light Beige
Wood trim requires clip:
3B0 867 175 A
2WE - Burr Walnut
1SG - Myrtle Wood
Passenger door trim (front and rear)
1J0 867 172 C
Rear driver's side door:
1J0 867 171 C
AC Control Cover:
1J0 819 157
A 93A - Myrtle
A 2WE - Burr Walnut
Climatronic Cover:
1J0 907 047
N 2WE - Burr Walnut
N 93A - Myrtle Black
P 2B9 - Black Anthracite Net Optic
P 2S2 - Black Silver Net Optic
P 2J7 - Satin Black Aluminum
P 2ZS - Black Brown Net Optic
P 4J4 - Brushed Aluminum
P 7AZ - Silver Gray
BoosTDIt
DC area - Fairfax,VA
The Last NA 2dr 5sp
Do you have any idea where i can find some decent quality photos of the so called "Satin Black Alu" or "Retro"
Tnx /images/graemlins/confused.gif
tongsli
Baltimore, MD
The P 2B9 - Black Anthracite Net Optic was also known as Platinum Net Optical.
Nice job Chris!
DC-TDIWagon
DC (really Fairfax county, but it is easier to say
2003 Jetta TDI Wagon, Reflex Silver
I wanted to get a new drivers door trim piece since mine hasn't held up. I have the burr or burl Walnut. The part numbers above show 3B1 867 171 C as the part but it isn't clear what the suffix should be. Is the F FEQ the walnut? It is listed in ETKA as nut brown as Kennedy lists it. Are they just inconsistent in ETKA and it really is burr walnut just being called nut brown? Any opinions? I'd hate to order it and then have to send it back with a restocking fee. They aren't cheap.
Ed's TDI
Victoria, BC, Canada
'01 Bora and '97 A4 1.8T Quattro (future TDI conversion maybe?)
Wow! This is an old thread!:eek:
If you call up a place that sells these (I bought mine through PG Performance) they can probably answer your question. Also, it'd probably be cheaper than ordering through the dealreship, if that's where you intend to get it from.
DC-TDIWagon
I made sure to make use of the search function before asking. :D
I wouldn't buy this from a dealer, I was looking at Impex and 1stvwparts. I hadn't called them, but they are probably going to find the exact same thing in ETKA that I found. I'll try and see but I was hoping that someone knew from experience. I suppose I could pull my current one off and look to see if I can find the part number on it.
Ed's TDI
I just got off the phone with Paul Jr from PG Performance and he verified the codes for the pieces you're looking for presuming you have a black interior (I presume your Silver wagon has a black interior)
3B1 867 171 C
Also, the clip piece that holds it onto the door is also available in Burr Walnut.
3B0 867 175 A
2WE - Burr Walnut
Paul was saying they don't carry the wood because it's apparently 4 times as expensive as the aluminum stuff! Good luck finding the parts you need!
