Interior fan on my 06 VW TDI Beetle only works on #4/full blast
Nero Morg
OR
Most likely need a new fan speed resistor. It's bolted to the bottom of the heater box, below the glove box.
Gothmolly
Providence, RI
2002 Golf
Are you sure it's not doing ANYTHING? Maybe your cabin filter is plugged up so low fan speeds feel like nothing comes out?
williambill
Dry Prong, LA
2002 Jetta TDI
Yup, as mentioned above, definitely sounds like a dead fan/blower resistor. Had this exact problem before and posted here about it and was given the same advice. Truthfully, I was skeptical at first till I finally found the wire diagram and confirmed the symptoms schematically. (This was on a Mk4 Jetta).
STDOUBT
Portland, effing Oregon
ALHx2
The same thing happened in my 1987 Toyota pickup and yep. It was the resistor.
That was before the internet, though, so I have no idea how I ever figured that out. :confused:
irvingj
Etna,NH
2005 Jetta Wagon TDI (PD)
Hey, Vince, it says Alberta, so how come you sound like a MA guy? Thanks for the video -- haven't needed that yet, but probably will in the future.
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
Yep, although it is no doubt the resister gone bad there is often a reason the resister heat protector "fuse" fails. I replaced a couple years ago in the 2001 until one day the smoke spewed out of the dash vents and the blower fan motor suddenly screeched to a stop. When the fan motor bearings (and or windings/brushes) wear out and cause extra amp draw from excess drag it can overheat the resistor. Eventually the motor is toast. Replace the resistor or heat protector "fuse" and see how much time it buys you.
06tdibug
North Carolina
2006 tdi beetle
Thanks for all of the replies. I have the resistor out which is attached to a plastic cover. Resistor is pretty dark and cracked. Appears to be made on to the plastic cover. Does any one know if the new/replacement part is just the resistor or does it come on a new plastic cover?
06tdibug
North Carolina
2006 tdi beetle
I have removed the blower fan. Has anyone ever taken the plastic piece off so you can clean the blower and oil the bearings?
ToxicDoc
Virginia, US
2001 Jetta, S7, .216
This was just posted in another section:
06tdibug
North Carolina
2006 tdi beetle
The brushes on my blower fan motor appear to have plenty of material left how much wear is allowed where the brushes ride on the armature
