D2000
I'm putting in a VW 1.9 TDI 1Z engine into a Suzuki Samurai. Originally, the 1Z engine had an intercooler. I don't have much room to play with as I already have an oil cooler that will take up a fair amount of room in front of the radiator. The 1Z has a lot more power and torque than the stock Samurai engine so I don't need the intercooler for that. I live in Canada, BC and I work in the bush and there are a lot of mountain passes and steep climbs. My buddy has a diesel landcruiser that is always over-heating and I want to avoid this issue. I have a large radiator and twin electric fans and aforementioned oil cooler. My questions are:
1. Is the intercooler necessary to keep temperatures down for a stock 1Z with upgraded injectors (DPC 520 nozzles)?
2. Would I get better fuel economy with an intercooler?
3. What would be an adequate intercooler for a 1Z engine with the 520 nozzles?
4. Would a top mount intercooler get heat saturated when driving at slow speeds in weather 30 celcius or warmer?
5. The turbo air output is right beside the intake on the manifold. If going without an intercooler is it ok to just connect the two with a short 180 degree pipe or should I lengthen the air route a bit before connecting to the intake manifold?
I greatly appreciate the help of any experts out there. Thanks!!!!
