Interanal pressure sensor
scyzoryk
Toronto
2015 Golf Sportwagen
Hi, after reset the engine light comes on after about 100Km driving. Any ideas?
VIN: 3VW Mileage: 191742km-119142miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 C HW: 04L 907 309
Component: R4 2.0l TDI H23 9282
Revision: 85H23---
Coding: 01190012832410081000
Shop #: WSC 93361 999 00000
ASAM Dataset: EV_ECM20TDI01104L906021C 004014
ROD: EV_ECM20TDI01104L906021C_004.rod
VCID: 254BAC5624E10F67CA-8070
13 Faults Found:
8844 - Torque Difference Cylinder 3
P1006 00 [096] - Limit Value Exceeded
Intermittent - Not Confirmed - Tested Since Memory Clear
8845 - Torque Difference Cylinder 4
P1007 00 [101] - Limit Value Exceeded
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 191740 km
Date: 2022.01.14
Time: 14:29:41
Engine speed: 1630.50 /min
Normed load value: 69.4 %
Vehicle speed: 63 km/h
Coolant temperature: 86 °C
Intake air temperature: 53 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.800 V
Unlearning counter according OBD: 40
Accelerator pedal travel: raw value: 38.28 %
Cylinder 4 bank 1 primary combustion position: -17.36 °
Cylinder 4 bank 1 internal moment: 89.7 Nm
Cyl. head: pos. controller main combust. 4 bank 1: limit stat.-Bits 0-7: 0
Cylinder head: controller internal moment 4 bank 1: limit stat.-Bits 0-7: 34
O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.3276
Setpoint generation interior torque: 117.6 Nm
8843 - Torque Difference Cylinder 2
P1005 00 [096] - Limit Value Exceeded
8823 - Cylinder 1 Internal Pressure Sensor
P13D0 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191624 km
Date: 2022.01.14
Time: 08:21:00
Engine speed: 1425.00 /min
Normed load value: 49.0 %
Vehicle speed: 38 km/h
Coolant temperature: 27 °C
Intake air temperature: 3 °C
Voltage terminal 30: 14.720 V
Unlearning counter according OBD: 39
Cylinder head: pressure sensor 1 bank 1: raw value: 40.320 bar
Cyl. head: press. sens. 1 bank 1: max press. in decelerat.mode: 0.00 °
Cylinder_pressure_offset_cylinder_1: 14.805 bar
Cyl. head: press. sen 1 bank 1: error stat. combust. rm. press.-Bits 0-7: 10
Cylinder head: press. sensor 1 bank 1: grp. run time: 29.8 µs
8825 - Cylinder 3 Internal Pressure Sensor
P13D6 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191624 km
Date: 2022.01.14
Time: 08:21:17
Engine speed: 1029.50 /min
Normed load value: 17.3 %
Vehicle speed: 42 km/h
Coolant temperature: 29 °C
Intake air temperature: 6 °C
Cylinder head: pressure sensor 3 bank 1: raw value: 0.109 bar
Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode: 0.00 °
Cylinder_pressure_offset_cylinder_3: 14.805 bar
Cyl. head: press. sen 3 bank 1: error stat. combust. rm. press.-Bits 0-7: 14
Cylinder head: press. sensor 3 bank 1: grp. run time: 30.0 µs
8826 - Cylinder 4 Internal Pressure Sensor
P13D9 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191624 km
Date: 2022.01.14
Time: 08:21:19
Engine speed: 916.50 /min
Normed load value: 21.2 %
Vehicle speed: 40 km/h
Intake air temperature: 5 °C
Voltage terminal 30: 14.700 V
Cylinder head: pressure sensor 4 bank 1: raw value: 0.109 bar
Cyl. head: press. sens. 4 bank 1: max press. in decelerat.mode: 0.00 °
Cylinder_pressure_offset_cylinder_4: 14.805 bar
Cyl. head: press. sen 4 bank 1: error stat. combust. rm. press.-Bits 0-7: 14
Cylinder head: press. sensor 4 bank 1: grp. run time: 30.0 µs
8824 - Cylinder 2 Internal Pressure Sensor
P13D3 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191624 km
Date: 2022.01.14
Time: 08:21:11
Engine speed: 993.50 /min
Normed load value: 83.5 %
Coolant temperature: 28 °C
Intake air temperature: 4 °C
Cylinder head: pressure sensor 2 bank 1: raw value: 12.758 bar
Cyl. head: press. sens. 2 bank 1: max press. in decelerat.mode: 0.00 °
Cylinder_pressure_offset_cylinder_2: 14.805 bar
Cyl. head: press. sen 2 bank 1: error stat. combust. rm. press.-Bits 0-7: 14
Cylinder head: press. sensor 2 bank 1: grp. run time: 30.0 µs
8804 - Cylinder 1 Internal Pressure Sensor
8806 - Cylinder 3 Internal Pressure Sensor
8807 - Cylinder 4 Internal Pressure Sensor
8805 - Cylinder 2 Internal Pressure Sensor
8809 - Cylinder 3 Internal Pressure Sensor
P13D6 00 [237] - Implausible Signal
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191653 km
Date: 2022.01.14
Time: 09:43:20
Engine speed: 1210.50 /min
Normed load value: 0.0 %
Vehicle speed: 47 km/h
Coolant temperature: 81 °C
Intake air temperature: 45 °C
Cylinder head: pressure sensor 3 bank 1: raw value: 26.203 bar
Cyl. head: press. sens. 3 bank 1: max press. in decelerat.mode: -0.35 °
Cylinder_pressure_offset_cylinder_3: -0.656 bar
Cyl. head: press. sen 3 bank 1: error stat. combust. rm. press.-Bits 0-7: 32
8810 - Cylinder 4 Internal Pressure Sensor
P13D9 00 [101] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 191716 km
Date: 2022.01.14
Time: 13:16:20
Engine speed: 1571.50 /min
Vehicle speed: 93 km/h
Coolant temperature: 91 °C
Intake air temperature: 58 °C
Cylinder head: pressure sensor 4 bank 1: raw value: 23.914 bar
Cyl. head: press. sens. 4 bank 1: max press. in decelerat.mode: -0.22 °
Cylinder_pressure_offset_cylinder_4: -0.461 bar
Cyl. head: press. sen 4 bank 1: error stat. combust. rm. press.-Bits 0-7: 32
Readiness: 1 1 0 0 1
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 50165000000088
Coding: 04FA6AA1242009750077020081CC2520562490004081A4B210630050C002
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
VCID: 479706DEFEADFD7718-8012
No fault code found.
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0361022423
Coding: 030C0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A716F2ABD5F909F97-806E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 02020124202100010005000000101400
ASAM Dataset: EV_ACClimaBHBVW37X 003018
ROD: EV_ACClimaBHBVW37X_003_VW37.rod
VCID: 428117CAD58FD85FCF-8016
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Component: BCM PQ37BOSCH 028 0145
Revision: -------- Serial number: 86582502150820
Coding: 00510B464041A2E949E44000091407001800000000000000000000000000
Shop #: WSC 00066 790 00194
ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
ROD: EV_BCMBOSCH_014.rod
VCID: 4A913FEAEDBF001F07-801E
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150118 043 0581
Serial number: 150402044915
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y15M02D13H00M23S22
Coding: 90A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST0004DHPN00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST0004DIFE00000
Coding: 191800
Relative Air Humidity Interior Sender:
1 Fault Found:
329480 - Heated Passenger Seat
B1806 F0 [008] - Safety Shut-Off due to Occupant Detection
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 72
Mileage: 191623 km
Date: 2022.01.13
Time: 19:59:50
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 20011503270862
Coding: 01000000280438
ASAM Dataset: EV_ACCMRRBoschVW372 001015
ROD: EV_ACCMRRBoschVW372_VW26.rod
VCID: 387575228353828F61-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01ZMF8
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002138
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 51A3288600E933C746-8004
Occupant Detection:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J150002L9RX0Y
Coding: 303136
Side Sensor Driver Front:
Subsystem 2 - Part No SW: ----------- HW: 480 001 102 15
Component: SideSensor_Df 001 0887
Serial number: 35700000000B602D921G
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 3 - Part No SW: ----------- HW: 480 000 302 15
Component: SideSensor_Pf 001 0887
Serial number: 3580000000048151031$
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 4 - Part No SW: ----------- HW: 480 400 302 15
Component: SideSensor_Dr 001 6149
Serial number: 3510002B1196FF54214%
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 400 602 15
Component: SideSensor_Pr 001 6149
Serial number: 3520002C71901D93A32$
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 400 202 15
Component: FrontSensor_D 001 6149
Serial number: 3550002B3192BC7091FA
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 202 15
Component: FrontSensor_P 001 6149
Serial number: 3560002B91901D9201B/
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20150224400102
Coding: 0400
Shop #: WSC 66564 385 16448
ASAM Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 040DD1D28F1B166FBD-8050
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 243 4270
Coding: 0BA412122980880902886A011000000000000000
Shop #: WSC 00066 790 00064
ASAM Dataset: EV_DashBoardVDDMQBAB 009037
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 64CDF1526F5BB66F1D-8030
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 23021510001793
Coding: 0901000800087300EF00020A080F00000001050000000000000000000000
Shop #: WSC 00066 790 00199
ASAM Dataset: EV_GatewConti 011020
ROD: EV_GatewConti_011.rod
VCID: 72E1870AA5AF28DF9F-8026
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0101
Serial number: 29150000484610065112
Coding: 30FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0035030
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B5F5A6E420539171C-807E
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000039123002
Coding: 5500000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 346D41129F3B66EF4D-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 160215060508CE
Coding: 003A13200000040000000000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 40851DC2DB83CA4FD9-8014
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000718473
Coding: 011000
1 Fault Found:
65593 - Switch for Central Locking
B122D 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 32
Date: 2000.00.00
Time: 00:00:00
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 438F12CECA95D157C4-8016
Address 47: Sound System (J525) Labels:| 5G0-035-456.clb
Part No SW: 5G0 035 456 HW: 5G0 035 456
Component: MIB_lite_amp H40 0060
Serial number: VWZ8Z1EC402D2L
Coding: 22000000AAAAAA0000
ASAM Dataset: EV_AMPMst12C1ALPI 001007
ROD: EV_AMPMst12C1ALPI.rod
VCID: 63CFF24E6A55B157E4-8036
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 030315060509V3
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 3F871E3EA67DB5B7A0-806A
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000852702
Coding: 091000
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Revision: -------- Serial number: --------------
Coding: 060A00010B000400
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
ROD: EV_HeadlRegulVWAFSMQB.rod
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 876 HW: 5G0 035 876
Component: MU-S-NS-US 014 0655
Serial number: V7B02502151928
Coding: 027302020000000021220002001800001F0100340100010546
ASAM Dataset: EV_MUStd4CPASE 002040
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 69D3E0668879EB072E-803C
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G0 919 605 K HW: 5G0 919 605 K
Component: ABT_Std_Nav H60 0030
Serial number: VWZ8Z9PS600HUW
Data medium:
Subsystem 2 - Part No SW: 5G0 919 866 S HW: -----------
Component: NAR 2015 --- 0022
Serial number: --------------------
1 Fault Found:
0020 - Tuner for Satellite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 32
Mileage: 191623 km
Date: 2022.01.13
Time: 19:58:43
Voltage terminal 30: 12.4 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
End-------------------------(Elapsed Time: 04:27)--------------------------
RIP TDI
Santa Barbara, CA
'15 GSW SE 6MT, '01 Golf GLS 5MT, '96 Passat variant
740GLE
NH
how old is the battery?
It seems like all faults are around the same mileage less than 500KM ago.
All faults were frequency of 1 and cleared since testing.
I'd also clear the faults and see if they come back.
