kmjunge
I recently completed a rebuild/refresh on my 98 Jetta. I have the engine back in the car, it runs and drives pretty well and I'm at the point of trying to work out all the smaller kinks. So here's what I'm running into in order of priority:
1. The instrument cluster warning lights all work but the speedo, tach, fuel level, and temp gauge do not work. I have done a voltage drop test on the engine block ground for the cluster and it seems to be fine. Is there something obvious I could have missed? The instrument cluster worked fine before I pulled the engine.
2. I'm thinking all my other issues are closely related to timing, specifically, the only fault code I'm getting is the N108 faulty/intermittent. My timing is all the way advanced (the vag-com reading is sitting at 255). The car drives but it has no guts (power). Before the rebuild I had the "00575 Intake manifod pressure control difference" issue but that appears to be resolved now (I installed new vacuum lines and intake hose). This leads me to believe my power loss issue is related to the timing and N108 fault code. Alternatively I guess it could be an N75 issue but I figure I should get the timing issues resolved first before chasing boost issues. Am I on the right track with that?
