Installing shorter rear shocks on Golf
bmwM5power
Rochester NY
15 GSW TDI S 6MT 02 JETTA TDI GLS 5MT 15 GOLF TDI SE 6MT 15 GOLF TDI SEL DSG
I have a set of Bilstein rear shocks that are about 20mm shorter ( compressed and extended) , is it a bad idea to install on MK7 Golf Tdi or do i have to pair them with the shorter springs, DG for example?
Cuzoe
Los Angeles
MK7 Golf S
Since 20mm isn't very much I would think you'll I be fine. Are the shocks from a different make... GTI/R or something? And what's your goal with installing these? You might not see any difference with that change.
bmwM5power
Rochester NY
Not really trying to achieve anything specific, my rear shocks need replacement and I just happen to have a brand new set of Audi A3 quattro rear shocks that are a bit shorter
thundershorts
west chester pa
2015 passat tdi sel premium 2015 golf s tdi gls tdi b5.5, 2002 eurovan,Peugeot 505 td,Citroen cx25 prestige
It might make a difference if the compressed length was longer than original shocks, uncompressed length should make no difference.
740GLE
NH
Rear weight of the GSW vs A3 might prove to be more of an issue than the length difference.
but if you have them free, noting to lose.
JELLOWSUBMARINE
yes
Define problem.
Are we talking front set? Rear? Both?
A set of 2 (unmarched handling dynamics to remainig O.E.set)
A set of 4 (set to range almost 1 inch lower)
nathanso
Redwood City, CA
2015 GSW TDI S 6M (sold)
Improperly sized shocks can top out. Happened to me on an E420 MBZ with an attempt to install Konis. Drove great but made an awful clunk very sporadically. If you opt to try the Audi shocks be mindful of the single-use stretch bolts used at top and bottom of the Mk7 GSW rear shock attachment points (2 top, 1 bottom):
P/N Quantity Price Each Description (Torque)
N10106402 2 $ 1.16 NUT. Lock. Arm. Mount. Cntl.
N10628301 2 $ 3.63 Bolt. Mount. Arm. Lateral. (70Nm + 180*)
N90648402 4 $ 2.51 Bolt. Mount. Bracket. Bar. Impact. (50Nm + 45*)
