MOGolf
- Joined
- Jun 27, 2001
- Location
- underneath something
- TDI
- 2001 Golf GLS TDI Reflex silver, rough road suspension and steel skid plate, 2004 Passat Variant, Candy White, rough road suspension and geared balanced shaft module, and much, much more. 2016 LR RR HSE TD6, 2019 Jaguar I-PACE
Installing the Rough Road suspension rear shocks and springs.
These parts are for the RR package, but the process is the same for any rear shock/spring replacement.
The complete shock parts are shown below.
Starting from top of shock (quantity two for job unless specified):
Nut N 103 041 02 (always replace, tighten to 25Nm)
Mount 3B0 513 353
Mount bolts N 907 583 01 or N 907 583 02 (two each side - four total, tighten to 45Nm)
Jounce bumper 3B0 512 131 H
BOOT 4B0 512 137 B
cap 1H0 513 268 D
shocks 4B0 511 115 DD
Bolt N 104 110 01 (always replace, tighten to 50Nm plus 1/4 turn)
Nut N 102 861 02 (always replace)
Installation steps:
Raise and safely support the car.
Remove wheel.
Use a jack to lift the axle to the point that it just starts to lift the vehicle off the support. I used a bottle jack pressing on a block of wood under the spring seat.
Remove the two upper bolts. (13mm socket required)
Remove the lower bolt and nut. (16mm socket/wrenches requied)
Remove the shock from the car. (BTW, that yellow paint mark is an identifying mark for the shock. Different shocks have different colors.)
You raised the axle so that there is no weight pulling down on the shock as you removed it. The same must be done when you install it.
Assemble the new shock to the upper mount and jounce bumper. If reusing the mount and old bumper, remove the old shock first.
Install the cap on the shock, assemble the boot to the jounce bumper, push those into the mount, then attach the mount to the rod. The new, larger diameter boot is required because these shocks are larger in diameter compared to the originals. Put a drop of a liquid soap on your finger, spread it on the ball end of the bumper, and then work the bumper into the boot.
Tools required: 16mm socket/wrench, counterholding tool for the shock. Here is the 3079 counterholding tool and special cutaway socket.
The old shocks have a mystery part. It protects the threads on the shock. I transferred it from old to new.
If you're going to replace the springs, now is the time to do it. I found it necessary to insert a pry bar in the axle tube where the lower nut is located and press down in order to remove/install the spring. I suggest replacing the spring plates (4B0 512 149) since they will be worn. They just slip over "posts" that keep them, and the spring, centered in place.
The springs shown (three white and one orange) are p/n 4B0 511 115 DD. Springs appropriate for a sedan, or without going up any weight range will/may be different.
Be sure to install the springs so that the ends of them are parallel to the line of the axle across the body of the car.
Install the shock to the rear axle, but leave the bolt loose. Raise the axle to position the shock and make sure there is now weight pulling down on it when you install the upper bolts. Tighten them, then tighten the lower bolt.
Reinstall the wheel. Lower the car (unless it is on a lift).
Repeat the process for the other side. Lower the car. Clean up.
For the curious, the shocks and springs had to come from Europe. They are not standard North Amerian parts.
Coming in another thread: The front struts.
Mount 3B0 513 353
BOOT 4B0 512 137 B
cap 1H0 513 268 D
Installation steps:
Remove wheel.
