So, i have an extra HPFP/CP4 with an unknown number of miles on it. i thought with all of the questions and concerns about this pump, i would show you all what makes this thing tick and disassembled it and photographed it.
if any administrators want to integrate or move it into any of the other numerous HPFP threads then feel free.
this is the label on the side of the pump. if anyone knows how to read this and determine what revision this one is or any other information please let us know.
this is the pump.
as a comparison, here is a CP3 next to the CP4. bonus points for anyone who guess what the CP3 is out of
this is what the inside looks like and the fuel flow
and an image borrowed from another thread. this is a nice computer model showing the insides
Fuel pressure regulator valve. this is what meters the amount of fuel that makes it into the plunger. more fuel will increase the pressure, less fuel will lower the pressure. i believe this works the same as the CP3. ie: with pulse width modulation. lower duty cycle will open the valve and increase fuel flow. higher duty cycle will close the valve more and restrict the amount of fuel going to the plunger. item 3 from image above
the FPRV is protected by a fine mesh screen on the input side of the regulator.
this is the spot that the FPRV bolts up to. you can see some fuel supply channels machined into the body. the hole in the top is the supply and the hole in the bottom is the exit to the plunger
plastic cover over the high pressure portion of the pump. this is easily removed with a screwdriver prying up between the discharge and the plastic cover
ta da!
