JFettig
First off, this thread is NOT for bashing, not for advertising, not for flaming, its for education!
Secondly, I sold all my pop testing equipment, I'm not pop testing stuff for you guys!
This is not a guide for n00bs, seatman: feel free to watch.
If you want to talk about how x process is better than y process in an ignorant manner, go elsewhere.
Images are unedited, I'm doing this quick because I just want to put this out there without putting much time into it, feel free to add constructive information
This thread is mostly about how to do 2 stage injectors.
First step - lap nozzle backs. Use a piece of flat granite and 400 grit sand paper
before:
during:
after:
The purpose of this is to ensure the needle is exactly flush with the back of the nozzle. this is primarily for setting the 2nd stage. You might have to lap these again if it leaks down fast above the first stage pressure.
It is extremely important that you don't pull the needle out, mess with it, or anything after lapping, look at all the grit in there!
Next, give them a bath in simple green/water in a HF ultrasonic cleaner:
The grit will come out, needle will fall out when you pick them up - usually, be careful. Take one out at a time, do not mix them up!!!
before:
during:
after:
