Injector bleed line air bubbles
Motohead1
charlotte
2002 bug+telephone pole
How quickly should an air bubble in the injector bleed lines at say cyl #1 move? I would think after driving a few minutes they would be clear but after 25 miles I still have air bubbles? What is normal?
See pics.
Drivbiwire
Zehntes Jahr der Veteran
Boise, Idaho
2013 Passat TDI, Newmar Ventana 8.3L ISC 3945, 2016 E250 BT, 2000 Jetta TDI
Bubbles are and have to be formed due to cavitation effect from rapid cycling of the injectors opening and closing.
Part of the reason VW uses Solid hose is so that people don't try to diagnose issues that are not issues which are normal and not easily understood by those not familiar with injector operation.
You should see the air bubbles formed in a common rail injector at 30,000 psi...Looks like soda pop rushing thru at high pressure via the leak back (control circuit).
Nothing to see here... Literally.
