Injector #3 or connector?
clyde
confluence, Snake/Clearwater
1998 Jetta, 1959 DeSoto with leopard-skin seat covers
Replacing a 214k-mile ALH in a 2003 with a low-mileage ALH from a 2001. Will use the car's four-wire glow-plug harness to match the car's electronics.
However, the connector to the third injector on the 2001 engine is a different style connector than the I3 connector in the car. My choice is to change the connector and use Injector #3 in the low mileage engine because it has the same miles as the other three in that engine.
Choice #2 would be to swap Injector #3—connectors would match; and engine would have high-mileage I3.
Opinions?
VE1.9
Chicago
2002 Jetta GLX 5spd
If you have a de-pin tool, you can easily swap the connectors since they use the same terminals. This seems like the easiest option.
Nero Morg
OR
You can also depin it with a paperclip. I'd swap connectors over, only takes a minute.
eddieleephd
Asheville, NC
2002 jetta Wagon
In my signature is the how to make the pin tool from windshield wiper blade metal.
This is what I have done.
Make the tool and Swap the plug, you need the small one...
Sent from my moto g(7) power using Tapatalk
