rjsummer
I have a 2000 Tdi ALH 5spd and my pump was leaking. I had the local bosch shop replace the seals but he warned me that the quantity adjuster might be slightly off and that they didnt have the equipment there to set it. So, he said they mark the top cover and set a jig against it to get it back really close to the spot it was before the repair. Got the work done, and car runs fine, leak gone, but now there is some white smoke when driving. Not tons but its noticable to the point where a cop might some day pull me over for having a smoky car. So, I'd like to try to adjust the quantities with VCDS, but I'm not clear on the values I would input. Can anyone help? Questions...
1. Are all ALH Manual cars the same values for adaptation and IQ settings?
2. If yes, where can I find a table of the factory or default values?
3. If I want to adjust the amount of fuel injected, I want a lower IQ number, but to change that I input an adaptation number... likely 5 digits long, right?
4. If I want to adjust the adaptation number up (less fuel and smoke) , by how much then? By tens, or hundreds or thousands?
