peace_of_soul
Thanks for a great afternoon; it was great getting to meet everyone.
What she said!Thanks for a great afternoon; it was great getting to meet everyone.
I did mine a few months ago. It is a 2 screw procedure. I would recommend the thermostat housing to be changed as well. It is a plastic housing that is very brittle. You will need to add some coolant afterwards because you will probably lose some during the install. You should use the VW coolant that you buy at the dealership. It comes 100% (not mixed) so you have to mix it yourself.What temperature should my NB run at ?
I managed to pick up an bluetooth OBDII connector for free (thanks to Carvoyant) and it was registering 150*F on the way to work today.
If I need to replace the t-stat, how difficult is it?
Tony W
I've got coolant leftover from when Growler did my TB, that should be plenty.I did mine a few months ago. It is a 2 screw procedure. I would recommend the thermostat housing to be changed as well. It is a plastic housing that is very brittle. You will need to add some coolant afterwards because you will probably lose some during the install. You should use the VW coolant that you buy at the dealership. It comes 100% (not mixed) so you have to mix it yourself.
I can help you out if you need help.
hmmm, $32 difference between the oem and aftermarket.http://www.idparts.com/catalog/product_info.php?products_id=2067
VW factory thermostat is what i used.
Where's the coolant temp sensor at on the NB? I don't recall replacing it...Yep, what they said.
NB's gauges suck without the temp needle, just the stupid muti-colored light.
I like to use VW parts as much as possible. I have seem T-stat's from Autozone that haven't worked right out of the box.
The only other thing I would suggest is if you haven't done your temp sensor yet, you probably should do that also. Since there will already be coolant spilled everywhere... They are cheap, too. Either one could be affecting your mileage a little too.
We've been buying B-5 (wife's Passat TDI, Deere 3520 and 997)Where do you buy diesel in Hamilton County? Owned a Ford 7.3 and it always ran better on CO-OP B20. This TDI is a whole different beast!
