TDI Tinkerer
Hey, so recently i checked the oil level of my '01 tdi jetta after the low oil light came on. To my horror, there was absolutely no oil showing up on the dipstick. None. I put in over 3 litres, and brought it up into the 'ok' level. That was MAYBE 2000 km ago. I checked again today and discovered that the oil level was significantly below the 'ok' mark. I have also experienced a fair bit of smoke on startup, but I had attributed that to the cold (average below -10 C, often -20 C) temperatures up here in Canada. Now, after doing a quick search, I'm hearing leaking valves, rings, or even talk of failing Turbo seals, Diesel runaways (which I now know how to combat) and Turbo replacements, costing just shy of $1000!
I'm a student, so this is not welcome news! I have owned the vehicle for 6 months, and haven't had issues really except I did replace the turbo actuator. So, I would like some help diagnosing the issue, as I don't have experience with turbos. I have heard that I need to check for oil in the lower Turbo pipe going to the intercooler, and if that's the case, I could have a runaway condition, or the leak could be on the other side, going directly into the exhaust. If anyone knows of a good right-up for diagnosing or is willing to walk me through the steps (I am fairly proficient with a wrench, I've worked a lot on my '79 f100)
As far as checking the compression goes, I've done it on my truck, but I am not sure how I'd go about doing it on a diesel... I'm used to just pulling the coil wire. I'd imagine that there is a solenoid somewhere that controls the fuel supply on my jetta that I'd have to unplug? Are there instructions for that too?
Also, i don't know that it's entirely related, but my EGR seems to be leaking oil. Also, I believe it's my oil cooler, that has oil residue covering it.
