I've had a couple oil tests done by Blackstone Labs on my 04' BEW TDI with 168,000. On the last test results the Iron levels doubled from the previous test. In the results write up they recommend checking the cam and lifters for wear/failure.
I pulled the valve cover yesterday and the cam and lifters looked ok to me. The cam lobes didn't have abnormal wear marks and the lifters didn't look worn at all.
Would the increased Iron be from failing bearings?
