ccaissie
- Joined
- Oct 24, 2018
- Location
- Lincoln County, Maine
- TDI
- 2002 Jetta TDI, 99.5 GL Gasser, 1989 jetta diesel n.a.
Going well, couple of questions:
1. The lower engine mount was a chore to remove...only after I pulled out all the studs, tensioners, water pump, etc could I drop it out the bottom and free the belt. It certainly would not come out the top with all the gingerbread still in there.....
So when I put it all back together, am I faced with a complex install of that lower mount/ belt and trying to install studs with the motor mount back up in there? If I was the smartest most experienced mechanic, what would I do?
2. Why pull the camshaft sprocket? Is it that hard to mount the belt with the camsprocket on?
Any info would be appreciated. This job is a bit more involved than my 99.5 gasser.....but will go well after a few little bits....
