PickleRick
- Joined
- Nov 29, 2017
- Location
- Greenville sc
- TDI
- 05 GLS BHW sedan 5 speed conversion. BHW Carver SantaCruz in progress
I'm using an 87 4 runner fuel tank. It is efi. For the sake of keeping it clean i was considering installing a low pressure in tank fuel pump.
Way back in 1985 the f250 came with a 490 engine and dual fuel tanks. Inside each tank was a fuel pump. 5psi and 40 gph.
5/16 diameter hose.
It is a simple 2 spade style terminal fuel pump.
Is 40 gph good enough for the bhw? I believe 5psi is what the oem pump put out.
5/16 diameter hose.
