compu_85
Gadget Guy
As most of you know the 2012 NMS models all have a rain / light sensor. The rain sensor / auto wiper function was disabled from the factory. Many chose to use VCDS to enable the rain sensor. The problem I observed is that the sensitivity isn't very good... the wipers are either going too fast or too slow and will often pause when they shouldn't, then go on high for a moment before slowing, then pausing, and repeating.
However, today I found there is an adjustment on the rain sensor!
With the doors unlocked connect to the body control module on address 09. Then go to coding, and pick the rain light sensor from the drop down, and press long coding helper:
Go to the 3rd block (Byte 2) and you'll see you can adjust the sensitivity.
The stock coding on our car was 0A. I changed it to BB. With the sensitivity switch on the stalk turned up all the way I found the wipers behaved much better.
I'll report back with my results on this, but I can already tell the auto wipers work much more sanely with the new coding.
PS: I'm curios what the coding is on the 2015 SEL models, which had the ran sensor active from the factory. Anybody have an autoscan they can share?
PPS: There is also an adjustment in the RLS for the headlight activation threshold. I turned it down one setting so the headlights turn on sooner.
PPPS: See here for info on turning on the rain sensing wipers: http://www.myturbodiesel.com/1000q/b7/vw-passat-auto-wiper-activation.htm
Thanks,
-Jason
Thanks,
-Jason
