DanG144
2 Micron Caterpillar fuel filters went on my cars as soon as I bought them.
But I wanted a water separator and water in fuel alarm.
I recently added some fuel filters to my 2005 Jetta BEW PD, as a test bed for ultimate installation on my 2010 (well my wife's 2010) Jetta Sedan CJAA.
I ran 3/8" fuel line to a pair of WIX 24770 filter bases, through a 30 micron WIX 33367 "mud" filter(changing to 20 micron FS1212 - a much better water separator) with a water drain, then through a 7 micron Fleet Guard FS19596 secondary filter with water drain and Water-in-Fuel sensor on it. A 3/8" line runs back to my Lubrication Specialist's MkIV 2 micron Caterpillar filter.
The filter head is mounted outboard the left frame rail, just in front of the left front tire, right behind the horns. Remove the bumper cover, drill 3 holes, use self tapping machine screws - mounted in 30 minutes. Most of which was spent trying to get to the bolt heads to tighten them. I plan to make access points from under the fender for easy access to periodically drain the filters.
The PD fuel system puts out about 9 psig at idle, out of of the filter set up to the tandem pump. As engine speed at full throttle raises to 4500 rpm, the filter system outlet pressure drops to 1.5 psig. This is the same pressure drop as the 2 micron Caterpiller filter alone - my gauges show no difference at all - though we all know it has to have some flow resistance.
I have not done flow and pressure readings on the 2010 common rail, yet.
There is a chance that I will need to add a second in tank fuel pump in order to assure positive pressure to the Aux fuel pump/tandem pump.
The WIF (water in fuel) alarm is not yet hooked up (or even bought) on my 2005 - it will be a stand alone alarm - probably just light up an LED.
I was hoping that one of you genius club members that works with 1's and 0's for a living can help me figure out how to hook it up to the instrument cluster WIF alarm that I have been told exists on the 2010 Jetta Sedan - it is just not used.
Total cost about $136.00 US. for the recent add on unit. About $125 for the http://www.lubricationspecialist.com/volkswagen-tdi/cat-2-micron-filter-system/ .
wix filter 33367 $7
Fleet Guard FS 19596 $38
Wix 24770 bases $42.
fittings (half inch pipe nipple by 2", two brass 3/8" barb to 1/2" mpt) $10
20 ft 3/8 fuel hose Mcmaster 54605K34 $26
Hose clamps $4
There are many other choices available. I chose to keep the same thread and base for all 3 of my filters. That way one can replace another in a pinch.
This is just a thread on what I am doing to my own cars. You are responsible to anything you do to your own car.
wix filter 33367 $7
Hose clamps $4
