Rickstah
Greetings, this is not the first time I have had these symptoms where it just suddenly won't start, it just cranks as long as you try it then stops. I think there were some past episodes where it would start doing it and after several sessions and some voodoo with various combos of pressing the fuel pedal to the floor then turning off and on the ignition and removing the key, it would sometimes fire up, I have no idea what caused it to start, lol. Anyway, this last time seems to be permanent, had to have it towed home from work, clearing all DTCs didn't make it start working so I guess it needs the delete treatment?
These are the relevant codes I think, below. I also have some abs intermittent codes and I need to put in a new harness but have been busy.
I did see one I have never seen before about the "key", too close to be a coincidence I think.
Is this where I send up a flare for @burpod , please?
3 Faults Found:
01316 - ABS Control Module
49-10 - No Communications - Intermittent
01321 - Control Module for Airbags (J234)
01176 - Key
65-10 - UnAuthorized - Intermittent
Chassis Type: 1C (1C - VW New Beetle (1998 > 2010))
Scan: 01 02 03 08 15 17 19 25 29 35 37 39 46 54 56 65 75
VIN: 3VWCP21C92M403114 Mileage: 274280km-170429miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 FF
Component: 1,9l R4 EDC G040SG 4104
Coding: 00002
Shop #: WSC 00066
VCID: 59B784F0C3D80353ED-4B18
3VWCP21C92M403114 VWZ5Z0Z5062618
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0 0 0 0 0
3 Faults Found:
01176 - Key
Coding: 00002
Shop #: WSC 00066
1 Fault Found:
