spiderb_151
Greetings!
I need some help with an originally stock 2002 Jetta Wagon with a 5-speed I picked up recently. Needed a fuel pump - that was easy. It runs good but gets crappy mileage, it's stuck at 36 to 39 MPG depending on how hard you drive it. Here's what I've done to try and fix it:
1. Compression check - comes up to 550 PSI on all 4 quickly
2. Cleaned intake and leak tested
3. Installed new larger injectors w/ appropriate tune
4. Logged data, requested vs actuals for groups 1,3,4,8,11 match closely, it does over boost a bit before it settles down - typical from what I've read??
5. Replaced MAF, at idle it was reading 450, now 360 - didn't help but it smokes a tiny bit less at WOT now.
6. Advanced timing to the top line in VCDS
7. Set IQ to 5 via hammer mod - software is still at 32768, all other adaptations are stock
8. Tested needle lift sensor
9. Got a "low smoke" tune from tuner - didn't make any difference, same smoke and poor mileage
Long drives on the highway with the cruise set to 70 it can get 39.5. What else is likely the culprit?
