Powder Hound
- Joined
- Oct 25, 1999
- Location
- Under a Bridge, Crestview, FL, USA
- TDI
- '00 Golf 4dr White 5sp, '02 Jettachero 5sp, Wife's '03 NB Platinum Gray auto(!)
I probably should have named this thread 'Why I do my own wrenching'. So, since my wife's car died yesterday and she had to get a jump to get home, I did some quick checking and decided the best repair would be to replace the alternator. The battery is a good one and should not have died so fast, so I am going to give it the benefit of the doubt. Particularly since the car started with 1 hour of charging at 12 amps and when tested with the engine running, there was only 11.16 volts measured across the battery terminals. I'd say that's pretty good evidence that the alternator just isn't doing its job.
The thing is, it's a New Beetle. Ugh. So. Blinkin'. Many. Fasteners. to get the front clip off. Yikes. There must be 200 on each side. There's more it seems to me, because I don't have power tools. The real number is 'only' about 36 on each side, or maybe a few more, but. I mean, seriously, my wrists are really complaining right now. And after 12 hours, I'm still about 2 hours away from finishing.
But I digress...
The real reason I posted this is not to display my snail's pacing at auto repair, but instead to show a couple of good reasons why I don't like to go to a Stealer. Or indy mechanics.
The previous owner of this car did, and probably paid dearly. Jim Ellis in Atlanta's name is not found on lists of dealer that do superb work for very reasonable prices.
How do I know? (Edit: I don't have direct evidence of who installed the junkyard alternator. Happy 3golf?) Well, for one thing, the alternator that died is not the original. It came from a junkyard. It had a pulley solid mounted - that is, no overrun bearing (or sprag clutch, I've never cut one apart so I'm not sure). The socket for the stator current was broken. And, well this one is a little nit-picky because the manuals got a 120amp unit while I believe the autos got a 90 amp unit since they don't have coolant heating glow plugs (this is an ALH vintage unit) and the junk that was installed in my wife's NB was a 90-amp. It's an auto, but really. It is so easy and no difference in price, really, to just install a 120 amp unit, so why not?
To add to the list of slip-shod work, there was actually a cigarette butt tucked into the works, along with a couple of folded business cards of Jim Ellis's service manager used to shim the right side headlight assembly because a couple of small bolts and their nuts probably vibrated loose, and it was easier to do that than to do the fix correctly.
I can't help but wonder how much the previous owner was shagged for these repairs.
The upside is that I finally tried Oil Hammer's recommendation on how to move the radiator carried off the front of the car without having it hang on the hoses to safely give yourself that room you really want so you can get to the alternator or a/c compressor. Now, if we can just figure out an easy way to pry out stubborn alternators, I'll be a happy man.
And now, the promised photos! Click the thumbs for a larger image.
The junkyard unit did not have the proper pulley.
And it came with the easy-release (read: broken) socket!
This is about how much extra room you can get in between the radiator fans and the engine accessories.
By doing this: (thanks, Oil Hammer!)
And last, but not least, what some service people do with business cards. Those 2 oval shaped brass liners should have a small bolt with a small nut on the other side. Looks like these 2 got away. No worries, at Jim Ellis VW, the service manager's business cards solve the problem right away!
Cheers,
PH
But I digress...
Cheers,
PH
