CanadianALH
2002 Jetta ALH had my car plugged in over night as it was a little chilly started up this morning no problem, pulled onto the highway 2 min later and about a min after that the coolant light started blinking, temps were cold but I pulled over shut the car off started it again no light the rest of the drive. I am going to let it sit 2pm and then I'll check the level I did some reading and it sounds like my coolant may be shrinking in the cold so if it's a little low I will add some. Now the coolant question, how good are the odds I have G12? I don't want to drain and flush the system right now as I don't have time. If it says G12 on the bottle I will add more G12. How likely is it a sensor or a bad connection?
