Fix_Until_Broke
I installed my IDParts Rear Swaybar last weekend and snapped a couple pictures along the way and figured I'd share how I did it. Nothing new under the sun I'm sure.
First I measured side to side and got the bar centered in the rear axle beam. Then I clamped the bar BELOW the beam as shown below. Mark the left and right side of the bar now so that, when you take the bar in/out while going through the drilling process, if there are any differences between sides of the bar they're accomodated for in the drilling.
Make sure to flip the bar over when you clamp it to the lower part of the beam - this will make your holes be at the correct angle. Make sure the front most edge of the swaybar is a little behind the front most edge of the lower web of the axle beam, ~1/16" or so. You'll see why this is important later.
Now that the bar is clamped to the beam you can drill ONE hole in the beam using the holes in the RSB as a drill guide. DO NOT DRILL A PILOT HOLE. I used the tightest drill that would fit (3/8") so the hole is located as accurately as possible. Once ONE hole is drilled in the lower web of the beam - put a bolt in it and tighten the nut down - that way the bar can't move on that end.
Then go drill one hole on the other end of the bar and put a bolt in that hole. Then go drill the remaining two holes in the bottom web (one on each side).
Now that all 4 holes are drilled in the lower web of the axle beam, flip the bar back over and slide one bolt through the drilled hole and up into the swaybar. It won't go all the way through since we have not drilled the top holes yet.
The hole was drilled the size of the bolt and I had to tap it in with a hammer - nice and snug.
Now go to the other side and install one bolt the same way.
BEFORE drilling the first hole in the top web of the axle beam, you'll need to pull the top of the bar back into the axle beam.
There's a rubber bushing in the center of the axle beam for the OEM swaybar.
Remember setting the front edge of the sway bar a little behind the front edge of the axle beam web earlier? Well, that rubber bushing is holding the sway bar "out" a little. Use the C-Clamp to pull the top of the bar in so that it's set back about 1/16" behind the front edge of the top web of the axle beam just like the bottom edge. Then drill the top hole using the same drill bit. The swaybar becomes a drill guide and locates the hole right where it should be relative to the bottom hole.
Install ONE bolt through and tighten the nut then drill one hole on the other side of the car. Similar to drilling the lower holes, the bolt(s) will locate the bar in the correct position while you drill the other holes.
Here's the passenger side all bolted in
On the drivers side, I had to make some special accomodations to maintain clearance over my 4" exhaust pipe. Instead of drilling a through hole in the top web of the axle beam, I drilled and tapped it for the bolt. I used the same method as on the passenger side - but used the 3/8" drill bit to just put a pilot dimple in the top web. If you look close, you'll see the dimple through the right hole below.
I then drilled it 19/64 (touch smaller than the tap drill size for 3/8-16) and tapped it with a long tap - again using the sway bar holes as a guide to get the tap centered and straight. The picture is blurry (cell phone), but that's a long tap that is 3/8" shank diameter so all I had to do was push and turn.
Continued on Next Post (dang 10 picture per post limit)
