veget8
Here's what I got today:
"Stone Cold" temperature sensor data:
Actual ambient temperature outside: 7.5 C
Fuel temp sensor: 10.8-11.7 C (toggling back and forth)
Coolant temp sensor: 10.8-11.7 C "
Intake air temp sensor: 6.3-6.5 C "
Unloaded WOT RPMs (redline is located at 4600)
Bosch TDI MAF : 4600, then immediately fall to 4250 and quiver
Pierburg MAF: 4600, then immediately fall to 4250 and quiver
Bosch 2.0 MAF: 4600, then fall to 4500 and quiver
Disconnected MAF: 4700 and holds steady. Noise, backfiring and lots of light grey smoke also noted, not present with MAFs connected
That's all I had time to get today. In all the cases I had the pedal to the floor until the car stopped accelerating. The missing plot is the boost with MAF disconnect. I will have to redo the run, but the RPMs maxed out at 3990 - definitely slightly higher than with any of the MAFs. Overall it had less power (low end and top end) as one might expect.
Also, note the interesting last plot- it was done on the interstate with the pedal held to the floor in 4th gear. Note the oscillation in the MAP actual, while the MAP request stays steady. Towards the end I started to go up a hill, so that's why RPM drops (not enough power to hold speed)
suggestion: If you want to compare any of these plots side by side, you can open them up in separate browsers. right click and go to "view image" or copy the link location and paste it into the new browser. If you have Firefox, you can use the tabbed browsing to rapidly switch between frames for an almost laid-on-top comparison.
Gotta run... I will post more later. Thanks as usual, lots of good stuff coming out here I think.
-Scott
-Scott
