veget8
Edit:
This issue has been resolved. Please see the end of this thread for the conclusion.
I have tried a lot of things, and I haven't been able to get my TDI running the way it ought to. I will paypal $100 to the first person who can tell me how to fix my car. This is not a joke or scam, it's an act of desperation
The car:
2002 Golf TDI GLS
Manual transmission
95,000 miles
Greasecar for the first 70,000 miles
Stock chip
DG Racepipe
Boost gauge
Symptoms:
Decent low end power, but lack of (almost no) top end power.
Poor mileage (34 mpg).
Top speed is around 75-85 mph depending on whether I am going up or down hill. Power is fairly good until about 2800 rpm, and then it drops off pretty quick. The car won't go past much past 3200 rpm in any gear, if it does, it creeps by it. If I jump hard on the pedal in first, there is a quick puff of black smoke around 2000 rpm.
Doesn't run rough, idle seems stable. starts a little hard when cold, but nothing that alarming to me for a diesel w/ 95,000 miles on it.
Around 3000 rpm, a VAG-COM shows MAF requested 800+ while actual hangs around 450-550 (average, with some oscillation above and below). I can post plots if requested.
Using the 2.0 MAF gives it considerable more pep, but still falls off around the same spot. Makes it smoke like the dickens, too.
Here's what's been done to the car since this problem developed, mostly in an effort to try to resolve it:
-Replaced MAF and did Cage mod
-Replaced air and fuel filters
-Descreened
-Cleaned intake manifold
-Removed EGR
-Checked cylinder compression. All cylinders between 400 and 450 psi with about 10% variation
-Replaced injector pump (and upgraded to 11mm)
-Replaced injectors
-Leak tested vac lines
-Tried replacing N75
-Checked for boost leaks
-Replaced turbo / exhaust manifold / actuator
-Replaced catalytic converter
-Mufflerectomy
-Replaced ECU
Feel free to ask questions if I can clarify anything. Thanks in advance to anyone willing to take a stab at it I am game for any helpful suggestions at this point.
The car:
2002 Golf TDI GLS
Manual transmission
95,000 miles
Stock chip
DG Racepipe
Boost gauge
Symptoms:
-Descreened
-Removed EGR
-Replaced injectors
-Mufflerectomy
-Replaced ECU
