You say you park on a crowned road and roll backwards when starting out. Sounds to me like you haven't yet figured out the engage/release point on your clutch and are spending way too much time between the floorboard and catch point (you are dragging the clutch out). Same thing will happen if you rest your foot on the clutch pedal.
Like many others have already said, practice in a flat parking lot. Taught my daughter to get smooth starts in just a few minutes and she has almost zero coordination (typical teenager). Try it, no throttle needed - complete stop with foot off the throttle, clutch all the way to the floor for the first start. Ease the clutch slowly, a millimeter at at time until you feel the clutch engage the pressure plate (should feel the vibration in your left foot), as soon as you feel that put the clutch back on the floor. Repeat a couple times. After a couple three attempts you should not have moved. Now try it again and let the clutch come up a little more until you start rolling forward, soon as you start moving put the clutch on the floor and let the car roll to a stop. Repeat a couple three times and you should now know the engagement point pretty well.
The only time my foot stays on the clutch pedal is from start out to the shift to second (usually because that is a quick shift) every other time my foot comes completely off the pedal.
Keep practicing, you'll get it.
How you place your foot on the pedal is completely unimportant. Use whatever part of your foot works best for you. This is actually somewhat dependent on the type and size shoe you wear. What is important is to practice enough so that your foot/leg "knows" exactly where the engagement point is for your clutch. With practice you will master that "magic spot" and all of a sudden, you know how to drive a manual transmission. Shifting gears is not the hard part, the hard part is starting from a stop. However, practice makes perfect. Taking a ride with someone who is adept at manuals might help with the finer points, but your real problem now is better solved with practice. Find an empty, flat parking lot and practice starting without touching the throttle. This will teach you the engagement point. Then all you have to do is to learn to coordinate your left and right foot together to give the car a little "gas" as your left foot reaches that engagement point. You are on the right track, just keep it up.How much of the clutch do you guys cover with your foot? I mean, do you cover the clutch pedal entirely, or do you partially cover it with your toes? I think I am more comfortable with the former. I don't know if one way is politically correct or if it is personal preference.
I also use the ball of the foot for clutch and brake. The entire foot for the throttle. No toe action.How much of the clutch do you guys cover with your foot? I mean, do you cover the clutch pedal entirely, or do you partially cover it with your toes? I think I am more comfortable with the former. I don't know if one way is politically correct or if it is personal preference.
That is funny because TDI's are known for their low end torque, I heartily disagree. If you lift the clutch to the friction point in first, it starts to roll for me. Easiest way to learn. Once you know where the friction point is in first, every other gear is a no-brainer.It has terrible low end torque
Well yeah, but EVERY car does that.That is funny because TDI's are known for their low end torque, I heartily disagree. If you lift the clutch to the friction point in first, it starts to roll for me.
Throw out bearingHow is being in neutral different than having the clutch pedal in? If I shift into neutral, can I let the clutch pedal out as fast as I'd like?
How would I be 'burning' the clutch if I am in gear and have the clutch pedal in? If the clutch pedal is in, the clutch is disengaged, right? So how is that causing wear to the clutch?
Trans in N you can let the pedal come up quickly, but I make sure it is in N.How is being in neutral different than having the clutch pedal in? If I shift into neutral, can I let the clutch pedal out as fast as I'd like?
FlyTDI Guy,I used to own MG's and they had a carbon bearing, not ball. I can't count how many people were faced with removing the engine to replace a $20 part because they 'rode' the clutch.
Every time a TDI drops below 800rpm a baby seal dies.I guess lugging the engine can cause the DPF to soot up quickly.
This. This. This.Like many others have already said, practice in a flat parking lot. Taught my daughter to get smooth starts in just a few minutes and she has almost zero coordination (typical teenager). Try it, no throttle needed - complete stop with foot off the throttle, clutch all the way to the floor for the first start. Ease the clutch slowly, a millimeter at at time until you feel the clutch engage the pressure plate (should feel the vibration in your left foot), as soon as you feel that put the clutch back on the floor. Repeat a couple times. After a couple three attempts you should not have moved. Now try it again and let the clutch come up a little more until you start rolling forward, soon as you start moving put the clutch on the floor and let the car roll to a stop. Repeat a couple three times and you should now know the engagement point pretty well.
Best mileage I've found for a TDI is to shift at peak torque or around 1700 rpm. This is not the best for the turbo or probably the dpf because you're also right at the lugging point.Any suggestions on shifting technique to improve mileage? aka shifting RPMs, etc. I've yet to break 40mpg on my 2011 Golf wagon TDi and I am trying to find out why.
This is how I taught both girls to drive a stick. With the oldest, there was a lot of subdivisions going in around us so after the parking lot, we went to the new neighborhoods. All streets were in with traffic signs but no cars or people. It also turned out to be a great place to try stopping and starting on a hill. This proved to be tricky in the beetle since I could not tell if she was in third or first from the passanger's seat. The youngest was picking it up but won't drive on the street. I was teaching her in my GMC canyon and her legs are too short to fully engage the clutch. She got the basic idea but not comfortable enough to drive on the street. No other manuals at home now, so she'll have to wait for us to replace a car.This. This. This.
This is how I learned. I learned in a 2.0 Beetle, but same basic principle. Started out learning in a flat parking lot. We had a community college near by so that's where I learned. Nice big, empty parking lot so I could get the basics of starting but also get going and shift into second gear. Started simply by learning how to start moving in 1st. As soon as I moved, stopped the car and did it again. Over and over until I started learning the engagement point. Then started moving and shifting into second. It only took a few hours of it. It wasn't until I really understood the engagement point that I even tried starting the car on a hill. But our driveway had a hill at the top, so my dad parked the car there and had me stop and start there. I only used the e-brake a few times. I never use it now and barely roll back. We lived in a really great area to learn manual. After I got the general hang of it, I drove the service roads next to the highway over and over and over. Stops and starts, 45mph speed limit so I could shift into all gears, and a few miles.
It took me a few weeks to really get proficient at it. I was driving to work a month later on busy local streets and I would stall out a decent bit on my way home in traffic. Probably once a day for a week or so. And that is certainly frustrating. But it really has become second nature. Do I still stall out cars? Yup. 8 years of driving a manual and it still happens.
Having a good teacher really helps. Its very hard to explain over the internet though. My dad started teaching me to drive, and then my boyfriend took over. They both were great. They had different methods, but I learned. I wouldn't want to learn on my own. You need to find a friend or something that can really sit with you and work with you over a period of days, rather than just taking a class.
Don't be afraid of stalling. It will happen. You will also learn the feel of the car about to stall and be able to save it.
Good luck!
Thanks for clearing that up, and here I thought it was me! She did that to me three times, real embarrassing to say the least. Now I just ride the clutch a bit and give her fuel, which I do not like to do, as I can see the clutch not lasting like I am used to. Like never having to replace "used to".The newer CRs are easier to stall because, as I understand, the computer won't let the engine drop below 600-700 rpms to prevent lugging. I test drove a manny Jetta and stalled pulling back into the lot, I was starting to slow and about the time I decided to downshift the computer shut the engine down. I guess lugging the engine can cause the DPF to soot up quickly.
I park on a somewhat crowned road and I don't believe I can move forward with only the clutch. Instead I roll backwards. So I need to give it a little gas first (maybe 1K RPM?) but again, I linger.
I still think that playing around with my seat distance might help at all.
I need to also practice downshifting because I notice my right turns are excessively wide. =/ I'm on my way to work, going straight, I've just shifted into 3rd gear and then a couple seconds later comes a sharp right turn on a very slight hill into a parking lot. To be fair it is a small entrance, but I am partially in the way of the left side where a car would exit from.
If you are rolling back what you need to do is practice on a very slight hill or flat ground will work.
Place the car in neutral let off the brake so it will start to roll back, now press the brake in just enough to hold its place and no more. Clutch in and selector in first now ease the clutch out till you feel the car start to squat down that is the friction point. If you let the clutch out a little more the engine should over come the brakes and move forward. At that time you can let off the brake and you will be moving forward. At this time you can ease the clutch out the rest of the way as slowly add fuel, as you practice you will get the hang of how fast you can ease the clutch out.
Now for the 1-2 shift this was the hardest for me to do smoothly. The only thing that I can say is wait for the RPM to drop before releasing the clutch. On my 02 if I shift at 2500 in to 2nd the RPM will be at 1000 and it seems like it takes an extra half a second or so to slow down the revs compared to all other gears.
If you feel embarrassed having a jerky shift with people in the car or the wife keeps saying "See this is why I don't want a stick" then just rev the car in first to 3000 and skip to 3rd.
Down shifting is fun and you will get the hang of it by blipping the throttle with the clutch in to rais the rpm about 1000. So if you are in 4th at 2000 and want to go to third you would clutch in shift into 3rd and then tap the throttle so the rpm is at 3000 and let the clutch out smoothly.
You can practice that easily on the hw with little to no traffic just get to 50-60 mph shift to neutral let the rpm drop to idle now tap the throttle so you hit the rpm that you were at to maintain the selected speed. After doing that try doing it and slowly releasing the clutch to put it back in gear.
Last never bother down shifting to 1st unless under or almost at 5mph, just use second.
Whew! Are you sure you're in the right thread? Nobody here is making any claims about correlations between driver intelligence and transmission choice. Regardless, I hope you enjoy your automatic [race car] transmission.Why is it that when ever it comes up on these forums we get a blast of manual transmissions are better and those who drive are smarter. Maybe I just like a car that shifts it's self and don't need another lecture about how smart the stick shift guys are and how stupid and lazy those who drive an autobox are. After all the DSG was designed for racing. Are all the current race car drivers stupid and lazy?
