tditom
- Joined
- Sep 5, 2001
- Location
- san antonio & austin
- TDI
- formerly: 2001 Golf GL, '97 Passat (RIP) '98 NB, '05 B5 sedan
daughter's ALH. Paramedick had replaced the IP a short time ago, so I knew the timing was fine. I don't have VCDS.
When I was ready to put the belt on, I marked the IP bolt head locations on the pulley before loosening the three bolts. After tensioning was set I moved the IP until the heads matched up to the marks made previously. Starts and runs fine. Next time she takes it in to Bruce she can ask him to check the timing. I'm confident it is 'close enough'.
