13'SportWagen
This morning I started hearing a weird rattling noise thinking its a timing sound. My car currently has 89k and is CPO, should I bring it in? Would VW replace at their cost if defective before the 130k recommended?
Why change before the OCI is up though?Im at 5k where I change oil. Im an old guy that's outlived a couple 200k+ ...
Emmisions in tact.Why change before the OCI is up though?
You've opted to keep your emissions system intact, yes? So you're using 507 oil?
If so, such an early OCI is likely more of a detriment to your car that you may realize.
Without going into full Bob Is The Oil Guy forums level of detail... the 507 oil has a few phases.
First phase is where detergents scrub off an old layer of deposited wear metals (like zinc) off the friction surfaces like crank bearings and cams.
Second phase is bedding down a new sacrificial layer.
Third phase is like regular oil.
Considering the OCI is 10k miles and you're doing 5k mile intervals you may or may not have a fully bedded down protective layer.
Have you been performing used oil analyses? Or just going off the old timey methods?
