I had Malone/Aaron put a tune on my Wagon at fest as well. It is good to have the options of different good tuners, and to feel the "Flavors" of the different tuners. I can honestly say that both of the tunes I have had on this car are very good tunes, and wouldn't feel bad recommending either of them to anyone.
I went with a stage 3 custom tune to go with my Bosch T4s, racepipe, and 3" turboback.
Had Malone add the Dynamic idle control to raise the idle to 1200 RPM until the coolant comes up to 150*, it then will drop down to normal idle speed.
Boost is maxed at 17.5 Sustained, and spikes to 21 when stabbed and quickly settles right down to 17.5-18. if you roll into the throttle it will not spike and just goes straight to 17.5 like it should.
it is almost 100% smokeless, and feels just as powerful and has a more linear power curve than my previous tune.
EGTs are lower on the freeway when climbing hills, boost does not go all the way up when climbing hills. it only raises a few PSI to hold speed on cruise, thus keeping the EGTs lower.
the dynamic idle control improved the shudder when taking off in 1st gear so well that I went back to Aaron and asked for a retune to raise my idle to 1050 rpm permanently.
this change, while minor has removed a source of frustration that I have had since I purchased this car.
I am well pleased with my new Malone Tune.
