I am doing a injection pump seal replacement today, Any pro tips?
vol4til3
Namibia
golf 4
I am changing the seals because its leaking like crazy and ruining my fuel economy, I also hate the smell of diesel every time I open my bonnet,
I am just looking for advice what to do and not do and what to look out for just in case a rookie like me ruins things.
the pump
super1
NY
none
Watch videos a few times before you attempt to do it on your pump
the pump
jmodge
Greenville, MI
I assume a VE pump? Clean things very well before disassembly, particularly around the pump head where you can’t see. A paint pencil mark before scribing lines to relocate the QA makes them easier to read. The same for marking the bolts that fasten it on.
Clean clean clean
csstevej
north nj
Where in particular is it leaking from?
shoebear
Colorado Springs, CO
1998 Jetta, 2003 Jetta Wagon, 2005 New Beetle, 2013 Sportwagen
Diesel will degrade rubber hoses. After you finish and clean everything up, check the hoses under the pump that got diesel on them -- you will probably need to replace them.
snakeye
Montreal, Canada
2003 Jetta and Wagon, GLS 5sp
Yeah I'd say inspect and keep an eye on them. If a coolant pipe simply swells up, it may shrink back down to its normal size once diesel stops leaking onto it, but if a pipe turns into a sticky black mess, I'd say it's best to replace it.
