puntmeister
A few more points:
1) There is only 1 highly accurate method of measuring MPG - manually keeping track of the amount of fuel you put in the tank, relative to the miles your drive on that tank. Any measurement based on the fuel gauge is worthless.
2) It is very important for MPG to keep correct tire-pressure.
3) I read through this thread - there were a couple posters who were confused over the idea of 'gliding in neutral'. PLEASE, do NOT glide down the highway with your clutch pedal pressed in the whole time! To make it clear - the idea is to put the gear in neutral, then REMOVE YOUR FOOT FROM THE CLUTCH!
4) Although the P&G method - ie, accelerate to 55, glide in neutral to 45, accelerate to 55...repeat repeat repeat....may result in optimum MPG, I am curious: who is actually able to pull this off over any reasonable distance?
I drive in a relatively modest population area - not rural, but not typical inner-city either - lots of flat, long, straight roads with few/distant stop lights. Yet, there is no way I could safely practice this technique over any significant distance.
As it is, I drive 55 to 60 on the highway, and that alone causes a lot of honking/angry drivers who are forced to go around me. I'd end up with a bullet in my head if I consistently practiced the P&G technique.
