tdipoet
i watched all of these videos while driving, and my mileage didn't go up at all.
It even says it in the car's owner manual - no fuel injected when in overrun. Take a look at the VW leaflet in my signature, page 12, which describes when each technique should be used....
I still find it hard to believe that there is NO fuel injection event at all during a "no throttle, still in gear" situation. My feeling is that there is about the same fuel injected as would be injected at idle.
You are completely forgetting (or ignoring) friction and pumping losses.Well a diesel engine doesnt actually "engine brake" as would a petrol engine. A petrol engine brakes itslef via restricting the air intake thus creating a vacuum on the intake stroke. Petrol engines are air throttle engines, air and fuel are always in the the same ratio. Though I imagine some of the newer DI petrol engines operate over a moderate range of air fuel ratios, nonetheless they are still air throttle engines.
Diesels are fuel throttle engines. They take a full gulp of air on every intake stroke, there is no butterfly valve to restrict air intake. Thus a diesel will run drastically different air fuel ratios at idle vs full throttle. And you get no intake stroke engine braking.
The only ways I kow of to "engine brake" a diesel are:
1. a "jake brake" which releases the pressure of the compression sroke so the cylinder has the drag of compressing air but not the power provided by the power stroke because the cylinder doesnt fire. This is the most effective form of "non friction" braking, but its loud and somewhat costly.
2. "Exhaust brake" basically a butterfly valve placed after the turbo, usually right after the turbo downpipe. This device simply creates a back pressure on the exhaust stroke, kind of analagous to the petrol engine creating a vacuum on the intake stroke via an air intake restriction.
3. Turbos, by nature are both gas pushers (they stuff air into cylinders) as well as gas restrictors (they inhibit exhaust gasses from escaping to the atmosphere.
And in my opinion this is what we are experiencing in our VW's...a nice little variable geometry turbo that creates an exhaust restriction when under light or no throttle, which creates a braking effect. I still find it hard to believe that there is NO fuel injection event at all during a "no throttle, still in gear" situation. My feeling is that there is about the same fuel injected as would be injected at idle. That why its more efficient to coast in neutral vs coasting down in gear, which has more frictional losses and that lil variable geo turbo in the way.
Read your manual, it is not recommend to coast in neutral with DSG.If I coast down hills in neutral, then put it back in drive with my DSG at highway speeds, will I cause any damage to the DSG tranny.
What I actually picked up from the manual is to just put it back in gear and it will be fine. Just make sure that before you do put it back in gear you are back to engine idle speed. I put mine in N a lot and no wear 25k miles so far on the tranny. Now if I could convince my wife her foot is too damn heavy and she should calm down I would net much better economy.Read your manual, it is not recommend to coast in neutral with DSG.
This is correct, in other parts of the world the DSG is programmed to automatically freewheel while in overrun.
So if you make sure you don't apply throttle until the trans is fully re-engauged there should be no more wear than is suffered during normal shifts.... And if you use N enough ( at idle & when coasting )and use it properly the trans will suffer less wear....
325K?Thanks for all the information, Vekke and others.
Is it better to coast in neutral or with the clutch depressed only? I ask because I did have a throwout bearing failure at 325k and I did practice hypermiling by coasting down many large hills with the clutch depressed. It may have been unrelated but I did want to check to be sure.
